Question about Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer
How do you get garmin gps map 498 to acquire satellites?
I turn on my garmin gps map 498 and it powers up normally and pages through all the menus ok but will not acquire the satellites even after 20 minutes. This is the model with the internal antenna and its out in the cockpit. Any suggestions?
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
SOURCE: not acquiring satellites
my GPS map 60CSX is not acquiring satellites. It was working fine until most recent power up.
Posted on Jun 02, 2008
SOURCE: Garmin GPSmap 76 not acquiring satellites
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
Posted on Nov 24, 2008
SOURCE: Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Posted on Dec 07, 2008
SOURCE: Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Posted on Dec 29, 2008
Garmin GPS GSMAP 182C Chartplotter will not boot up
If the unit doesn't go further from the reading card. this may indicate that theres a problem in the memory card.
Not being able to a get a signal lock on satellites would indicate a problem either in the software something is wrong or not geting loaded correctly (the memory card) Or a hardware problem.
You may have to take it in for service if you are unable to check the memory card or replace it.
Jun 27, 2008 | Garmin eTrex GPS Receiver
My Garmin quest unit has stopped acquiring satellite signal. All other functions appear normal.
I had a similar problem - and was told that the issue was with the satellites not the unit and that it would be ok in a couple of days. Mine is now working OK again.
Jun 23, 2009 | Garmin Quest GPS Receiver
Nov 07, 2008 | Garmin GPSMAP 498
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't change location-appears as if still in Kansas despite downloads
You need to go outside and turn on the Garmin until it has acquired a satellite lock (15-20 minutes). Kansas is the default location (Garmin Headquarters). Once you have acquire satellites, the Garmin will remember the last position as the starting position when the power is turned off. You know you have acquire a satellite lock once "Ready to Navigate" appears on the top of the screen.
Jan 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble Acquiring Satellites
This can be easily fixed....
I had the same problem, I returned first piece and exchanged for the second. Had the same problem with second and took back to Circuit city. The GPS guys took out 3rd one for me and had same problem. Then the manager came who has been using these for couple of years and tried to set the home location 3 times and it worked 3rd time. He did the same for the second returned piece and it also worked. He says since these pieces are programmed for Kansas we need to give 3-4 tried before the piece first 'locates' satellite and then acquires satellite. After the the piece just turned out to be awesome.
Oct 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin Gpsmap 498, External Antenna With Dual Frequency Transom Mount Transducer Logo
105 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
