Question about Welding Tools
Settings to tig 3mm alloy pulse mode with a jasic tig 200 ac/dc
2 Suggested Answers
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
What settings do i use to arc weld.
Not sure what machine you have, but it should be DC straight (electrode negative or DCEN) and DC reverse (electrode positive or DCEP). The polarities have different characteristics. For example, if you're planning to TIG weld, you would either use DCEN or AC (if welding aluminum). For the general stick welding process, DCEP tends to give you a deeper weld. The welding rod you buy will have recommended machine polarity and amperage range settings, you should use the recommended polarity for whichever rod you're using because different rods are designed to weld under different circumstances. But, generally speaking, most welding rods for steel will work on DCEP without much trouble.
May 17, 2016 | ARC Welding Tools
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
GIANT WSE 200 amp ac dc tig welder
Buy a new circuit board as it will be cheaper in the long run as the solder has damaged vital parts on the board. It will take a lot of frustration in fixing all parts .
Apr 04, 2013 | Welding Tools
Lincoln 185 TIG pulse control inadvertently kicking on and off.
welding aluminium requires a bigger current draw that with steel and to weld aluminium it is a dc current requirement
what you are seeing as a pulse may be the unit going into overload
Jun 20, 2017 | Lincoln Welding Tools
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
My giant wse 200 tig inverter single phase AC/DC welder wont power up when plugged in have anyone got a wiring diagram.
Sep 26, 2009 | Hobart Welders Champion 500433A Factory...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
91 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
