Question about Behringer Bx4500h Ultrabass 450w Bass Amplifier
Picture potensio volume out....'' - Behringer Bx4500h Ultrabass 450w Bass Amplifier
Is there any way to connect my casio ctk1100 to a laptop??
Yes. But it depends which connectors you have on your laptop. If you have a small (3.5mm) stereo jack input, then you need one cable with a small stereo 3.5mm jack on one side and a big stereo 6,3mm jack on the other side. (Take a look at the picture below).
Then you plug in side with a small stereo jack in your laptop "line in" input and other side of the cable with a big stereo jack to your Casio CTK-1100 Phones/Output plug on a keyboards rear side...
Be sure to adjust the volume on both the Casio (output volume) and laptop (input volume)...
Cheers!
Mar 01, 2017 | Casio Music
Where can I find the best volume pedals?
Currently, the best top 5 volume pedals are:
1. Ernie Ball VP Jr. P06180 250K Potentiometer for Passive Electronics
2. Ernie Ball MVP, Most Valuable Pedal
3. Boss FV-500H Volume Pedal - High Impedance
4. Dunlop DVP3 Volume(X)
5. Mission Engineering VM-PRO Volume Pedal Pro with Buffer
You can check their reviews here:
Best Volume Pedal Top 5 Best Volume Pedals Reviewed by Musical Study
Feb 22, 2017 | The Music
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
I need a picture of wiring diagram for volume an tone knobs for a washburn lyon LI15. 4 knobs.
I would imagine it to be similar to this. this is standard wiring for your situation. although you may not have these exact pick-ups. the wiring remains the same. Good luck
May 26, 2015 | Washburn Music
What yr is my Epiphone valve junior serial number 11050738
For the best answer contact Epiphone directly at http://www.epiphone.com/Home/Talk-2-Us.aspx
Feb 01, 2015 | Epiphone Music
My ME 70 is auto skipping. Example, from one effect to another without me touching any button. an electrician said it just need cleaning, but even after he cleaned it, it still has the same problem. please...
"Auto skipping. Example, from one effect to another".
Is it always so, or only sometimes?
What type of effect? Is it happen at the all Type of parameter? It can be observed from the changes sound is heard.
Yes "it just need cleaning", but, which parts are cleaned,and how he did? Is it potentiometer?
And if he simply cleaned by spraying contact cleaner, this is not effective at all, because it does not touch at all the inside of the pot.
Potentiometer need to be replaced, but if it is difficult to find, open the back lid of potensio. Fix the inside (you have to understand the potentiometer structure inside).
ME70 pots are look like this :
Sep 12, 2013 | Boss ME-70 Guitar Multiple Effects Pedal
When i'm on "clean" my
Volume is a relative thing and our ear's perception can be quite different than what we expect. With distortion the spectral energy is spread out from the spectrum on the clean setting. The ONLY way you can check the output is with an oscilloscope looking at the output waveforms. The RMS output under distortion will "appear" louder as the waveforms are squared up and nearer flat-topping a lot compared to the output when clean. The amps have several gain stages and the numbers on control settings have very LITTLE meaning regarding whether the amp is near max. Only checking the output waveform with a scope will give a true picture.
You should procure a sound meter also to help in measuring sound pressure levels. There are OSHA limits for hearing protection now to pay attention to.
Feb 12, 2011 | Peavey Vypyr Tube 120H Amp Head
I'm missing the volume pot and dont know which one to buy. Its a champion 30 dsp fender guitar amp. Thanks
There are two volume controls. One is "drive volume" the other just "volume"
The plain volume control is a 50K ohm, linear taper.(A) old marking
The Drive volume is a 100K ohm Log taper.(C) old marking
Find suitablel parts at DigiKey.com or Mouser.com or find a Febder repair center to order the part.
From other than Fender, You may have to shorten the shaft with a hacksaw to match your needs.
Jan 10, 2010 | Fender Fm25dsp 1x10' Guitar Combo...
Lacking volume
We used canned air to blow dust from the volume control slider connection. It did increase the volume, not quite to the original level, but to an acceptable level.
Dec 05, 2008 | Music
Behringer Bx4500h Ultrabass 450w Bass Amplifier Logo
22 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
