Question about Pioneer Audio Players & Recorders
Pioneer djm 600 will not power up
While playing at a club, my pioneer djm 600 developed a load cracking noise, then stopped working, will not switch on now ? checked all fuse`s and are o.k ?
SOURCE: my pioneer djm 600 mixer
replace the whole heaphone jack!! Replace it with a new metal 1/4 in. 3 piont jack that you find at any radio shack for a couple bux(these are also the same type of metal 1/4 in jack you'd find on an Allen&Heath brand mixer). The factory one on pioneers is a cheap plastic (Sony ,I believe) peices of **** ,and they always go out or brake. It's not hard to do it yurself though. As long as you can solder and have some apptitude for basic electronix ,you can do it yurself. You'll have to remove all the plastic knobs. then remove the 6 screws on the top plate; the four corners and the sides from the top panel. Don't forget the 2 on the outside of the crossfader ,and the 2 at the top for the mic xlr plug in. Then the top panel/plate should come off easily. This should expose the heaphone jack and enable you to remove it. There's a cheap plastic nut holding the jack on ,remove that and gently pull out the headphone jack till the wire slack catches. cut/snip the wires as close to the headphone jack as possible ,noting their placement! Remove sum jacketing from the ends of the wires ,and solder them back into place on the new metal heaphone jack make shure to test the jack out before putting everything back together!!. Follow the forehand instructions backwards and wahlah. You'll probly never have to replace the headphone jack for the rest of the life of the mixer. I've had the same 500 for 5 years now. The headphone jack went out on it in the first 6 months I had it. I replaced it my self and its werked fine and minorly trouble free for years past. I had to retighten the top nuts once or twice over the years ,but no biggy. Hope this helps! good luck
Posted on Oct 25, 2008
djproaudio
  • 515 Answers
SOURCE: pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 black Professional DJ power on but not working!!
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
A DJ Pro Audio Co.
SOURCE: i have my pioneer djm 600 for about 5 years. I
You've got dirty pots mate! You need to clean all the dust and **** from inside the sliders and the circular trims. The plastic shaft ALPS pots in the DJM600 don't have a sealing bush so if you pull the knob off and spray some "no-residue contact cleaner" down the shaft you may get it to the bottom. DO NOT use WD40 as that leaves an oil and will clog the pots (as the oil will eventually mix with new dust and make a gloopy paste) This would then break the sweeper contact with the resistive surface.
Virtually all the ALPS pots on the 600 are stereo so as you have lost a channel some of your pots have lost connection already. Cleaning may help but if not you may need to strip down desolder the troublesome ones and replace (or if your feeling brave bend open the tabs and clean internally)
Don't worry though. I got the right cleaner (electronic use no-residue stuff) from a car accessory shop and it all started working again without opening her up.
Posted on Mar 20, 2009
SOURCE: Pioneer DJM 600 mixer keeps blowing ic 557 fuse on
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Posted on May 27, 2010
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Help with set up
connect your gemini phono out to -------- pioneer phono in.
Jul 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Power shortage with new djm-600 US model used in UK
if it is a grounded power cord make sure the voltage is correct some are 115v and others are 220 also some have switch to select voltage plus there is two fuses on that particular model check both and replace with same volt and amperage if it does'nt work reply back to me!
Nov 01, 2007 | Pioneer DJM-600 Silver Professional DJ...
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
