Question about Ashley Furniture ASHLEY 8050025 Rocker Recliner
Return it back to the shop immediately! - Ashley Furniture ASHLEY 8050025 Rocker Recliner
Long download time with my majic jigsaw puzzle just got my computer back from the shop they say it will take a longer downlong time is there any way I can speed it up
They may be aware that Microsoft will try to install patches not yet on your computer because it was in the shop and not online. You need the critical patches and there is really not a way to speed that up. Your antivirus will be updating itself as well.
After your computer "settles down", i. e. installs its updates, you might recover some speed by running Adanced System Care. But I would create what is called a restore point before using ASC. If you immediately encounter problems, use the restore point to recover and return the computer to a pre-ASC status.
Sep 14, 2017 | Puzzle Toys
Why will my MaitreD winer cooler temp not lower
Is the fan coming on? Is the condenser coming on? Sounds typical of a t stat to immediately return to room temperature display on the display.
Jun 04, 2016 | Heating & Cooling
Turns off immediately after turning on! It's brand new. Duracell 300
You should have warranty. Return it to the shop where you bought it.
Aug 18, 2015 | Duracell Cameras
Does bird food have to be fresh?
Just likewith human food - fresh food is best for birds but that's not always practical.When you buy bird food, check it for any obvious infestations of bugs and grainweevils. If you find any, return it to the shop immediately.
Jul 24, 2012 | Birds
Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Radio Communications
Just recently paid $836.00 for projector repair. Unit would not power ON, power indicator flashing 3 times. They said they replaced the DMD board. We asked to see the replaced part but they did not have...
If unit is working now, the repair is valid. Parts, like DMD are quite expensive and require core to return. Example: Main Board for Panasonic plasma TV cost $525+. When repair shop return a dud(core), they get $250 credit. Even some used parts, like light engine, require dud return(if you wish, of course) to get $50 back. So: now you know how it works. I won't blame them for immediate dud return, due to high cost of the part(s).
Especially for Panasonic. For the boards they require prior authorization. I've got into that mess couple times. Hope, that repair worked out well for you. If not, I might give you a second opinion, but I need to see and open your projector. It's up to you.
Sincerely,
Alex. C/o Alex's Television, 215-806-5980(Philadelphia, PA)
Dec 08, 2011 | Panasonic PT-D5600U DLP Projector
My new shop vac is smoking and smells like electrical fire. Any suggestions? Should I just take it back to the store?
Hi. ABSOLUTELY return it. It has an internal electrical issue which may cause a fire. Return it ASAP!! J.
Aug 09, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
We were having issues with its lack of suction - we took it to an authorized Dyson repair shop and now sparks are shooting out and its smoking! What the heck is wrong now?
SO MUCH FOR REPAIR SHOPS. WHEN THEY PUT THE VACUME BACK TOGETHER THEY MUST OF PUT IT BACK TOGETHER WHERE SOME THING IS RUBBING TO CAUSE THE SPARKING YOU SHOULD RETURN IT TO THE SHOP AND COMPLAIN, THEY SHOULD NOT CHARGE FOR THEIR MISTAKE
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Ashley Furniture ASHLEY 8050025 Rocker Recliner Logo
Top Ashley Furniture Furniture Experts
Lawrence Oravetz
Danny Kuhlmann
Are you an Ashley Furniture Furniture Expert? Answer questions, earn points and help others
