Question about Garden
Honda hr194 blue smoke out of exhaust then clears
3 Suggested Answers
SOURCE: Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
Posted on Dec 09, 2009
  • 6468 Answers
SOURCE: honda hr194 won't idle.
check the air filter if ok clean the carb jets
Posted on Aug 14, 2012
My 2006 vtx 1300 after changing oil, air filter on max throttle position from exhoust pipes goes black smoke. What it could be?
Hi, Martynas your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
VTX 1300C Stock exhaust One exhaust pipe spits out black smoke when...
smoke from exhaust
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
May 21, 2017 | 2006 Honda VTX 1300 S
Hi my 1999 Honda ace deluxe 750 blows blue smoke out exhaust when warmed up could it be valve adjustment
No that is either poor ring seal or loose valve guides, you need to rebuild the engine most likely.
Nov 10, 2016 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
Too much oil in 1995 honda
Did you overfill your car with oil? Did you check the dipstick? Is that why you are thinking there's too much oil? What color is the smoke coming out of the exhaust? If it's white, you could have an issue with the piston rings, as the oil burns it's leaking out through the cylinder piston rings if they are worn down.
Jun 02, 2016 | 1995 Honda Civic
Why do I have blue/white smoke coming out of my exhaust?
Appears you are burning oil intermittently. Ring job in order.
Oct 10, 2015 | Honda XR 650 L Motorcycles
Blue smoke in my 96 honda prelude
Blue smoke is usually an indication of oil burning. If you see blue smoke and hear a loud sound it could be a few things. The biggest being you have a hole in your block. You could also have a leak in your exhaust and be burning oil. A quick trip to a local autoparts store should answer this question. Most employees are willing to lend an ear and have experience with cars.
I recomend you dont take the car on anything other than short trips untill your problem is found and solved.
May 05, 2014 | 1996 Honda Prelude
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
1984 Honda VF 500 F white smoke tail pipe
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
White Smoke from Engine and Exhaust GL1100 Information Questions...
Coolant to Exhaust Leak
Honda V30 Magna VF500C Manual
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Apr 05, 2014 | 1984 Honda VF 500 F
EXHAUST TROUBLE SHOOTING
If smoke is black indicates too much fuel
If smoke is white Could be coolant in the exhaust system
If smoke is blue possible excessive oil entering in the combustion system
Also if you have an automatic transmission with a vacuum modulator, it could be leaking transmission into the combustion
If you have too much oil in the engine, it will also smoke
May 06, 2013 | 2007 Honda Accord Sedan
Honda hr194 won't idle.
Aug 13, 2012 | Garden
Hey Graham:
Enjoy!
Steve
May 09, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
