Question about Freezers
Lights flashing on Hotpoint FF187E Fridge Freezer
Woke up this morning with the freezer door slightly ajar and a pool of water on floor. The lights are flashing on top of fridge freezer. Still feels cold inside fridge and freezer. Will the food be ok to eat? Are the lights flashing as the door was open all night? Food is still solid frozen in freezer. Thanks. Cant find manual!!
Regards
Jenny.
  • 1 more comment
  • jennyrich71 Jun 23, 2009
    Hi, did what you said, lights are still flashing an hour later. Is this normal?
    regards,
    jenny
    hi the model is a Hotpoint FF187E. the alarm is not sounding. 3 lights are flashing at top. The supercool light is flashing amber. The power light is flashing green and the super freeze light is flashing amber. It seems cold and you can here noise to say its on.
    Thanks
    Jenny
  • jennyrich71 Jun 24, 2009
    Thanks for manual we resolved it!
  • 749 Answers
Hi, there is nothing to worry, if you can see ice on the food and feels cold it will be ok, the lights indicate that the freezer has been open for a long time, now close the power and clean any water and turn it back on, within 30mins the lights should go.
Regards
Posted on Jun 23, 2009
  • 2 more comments
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jun 23, 2009
    can you tell me which one's they are what color? also is your freezer cold as it should be? please give the make and model of the freezer thanks.
  • Muzzammil Ishfaq
    does the alarm sound?
  • Muzzammil Ishfaq
    there are three lights on the freezer how many of them light up?
  • Muzzammil Ishfaq
    hi, i have found a on-line manual for your fridge/freezer it has a troubleshoot section on page 10, check it out. Link
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
The door was left slightly ajar for approx 1 hr
well that light is the thermostat light and you should increase it for better performance.
Feb 18, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
Hotpoint Whirlpool upright freezer. The lights all work but the temperature is slowly dropping - now only -7 C and the freezer is silent. Before this the temp lights kept flashing and vibrating (quite...
Problem has sorted itself out. We removed and gave away quite a lot of food from the freezer and cleared away some ice that had accumulated on the temperature sensor. When we checked this morning the temperature had returned to -24 C so we don't need to go in search of a new freezer today, thank goodness!
Dec 27, 2009 | Whirlpool Freezers
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
Freezers Logo
425 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
