Magnavox LCD tv light blinks green& red but won't turn on
mistersony
  • 320 Answers
SOURCE: 42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Posted on Oct 19, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
  • 92 Answers
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
Posted on Sep 07, 2009
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Magnavox 52" LCD tv blinks red and will not come on (by the remote or the power button on the tv). I have to disconnect the tv from the wall plug for few seconds. It will come on green and work...
Ur power supply board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 23, 2010 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
