I have a defy laundromaid 920 but the inlet hose wont let water go through.
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
May 11, 2017 | Washing Machines
I have a Defy electrologic laundromaid 1300 washing machine that the cold water runs in even when the machine is switched off.
Your solenoid operated valve is stuck open on the cold side. To find this valve, follow the cold water inlet hose and it will lead you directly to it.
Feb 01, 2017 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My Defy Laundromaid Electro Logic 920 is showing and 'EU' error msg. How do I clear this.
disconnect the power cord from outlet box by 45 seconds. Hold the power button in OFF. Connect again and try it.
If this do not resolve the problem, you must call to the company or some tech service for fix it
God bless you
May 28, 2013 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
