Question about Pool & Spa
Hi there i carnt get miy heater to come on and filter sysyum , bought new pump and curcit board but still same could u help
Carnt get hearter and filter system to work
    New Friend:
  • 45 Answers
First make sure that the Pump runs, if water does not flow thru the heater assembly, the heater will not turn on..., else the water would super-heat. If water is flowing thru the heater assembly, check your output from your thermostat if it is working. If not replace thermostat. If it is ok, then check to see if Pressure switch is working by using a meter and see that it is open circuit when the spa is off and a closed circuit when the pumping water. If not, then you may be able to adjust your pressure switch if it has that capability. If not, replace pressure switch. If however, the pressure switch is ok, then you should test the voltage at the heaters element. If there is voltage, then you need a new heater element. If not, then I need a more detailed description of the problem.
Hope this helps,
Dan Osko
Osko Pool n Spa
http://www.oskopoolnspa.com
Posted on May 16, 2014
Watkins vanguard spa will not heat
bad heater element if ok bad recirculation pump
Aug 21, 2017 | Pool & Spa
Hi. I just bought a house with a pool and Raypak RP2100 heater. The pool company came out and opened the pool and started the heater. It ran for a few days and has quit running completely. the pilot light...
Thank you for posting your question here on Fixya.com.
What type of filter do you have: Sand, Earth (DE) or a cartridge? The most likely reason it worked and has since quit is your filter has become dirty enough inside that the flow thru the pump and heater are reduced too low...there is a switch in the heater that senses this and turns the heater off to avoid boiling the water. Cleaning or backwashing the filter should fix the problem. If you have a sand filter or a cartridge filter look at the valve and see if there is a recirculate setting. If so, turn off the pump and change the valve to this setting. Turn everything back on...the heater should start to work. This would verify the filter just needs to be cleaned.
If you need help with the filter please add a comment with the filter details.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 19, 2011 | Raypak 130,000 BTU Natural Gas Pool...
Pool pump shutting down -- heater?
Trying to get the TA correct before you kill the alge? Leslies diagnosis?
You probally just need to kill the alge before you do anything. Nevermind the TA for now and just add about ten gallons of liquid chlorine. The alge untill you kill it will plug the filter constantly. This will give you the code on the heater and will make the pump run very hot and will hurt the plumbing by shrinking it. This will stop water flo by letting air in also it will leak water at the pump discharge.
A lot of liquid will break the alge as it is unstable, but use a lot.Once you kill the most of the alge then add probally another four gallons and now brugh the whole thing real good. now you can start running again and start with all the stuff they will sell you to adjust the PH and TA. I hope this helps, and good luck.
Jul 13, 2010 | Rheem 266K to 399K BTU Swimming Pool...
The letter & noumber a90 is on the screen & wount move i can not get the camera to work i can not get the menu or display on screen
Hi there display LCD is damaged Or its disconnect from curcit board . Replace that LCD if damaged.example curcit board image in below.
Common problem.
Mar 23, 2010 | Pentax *ist DL Digital Camera
Heater slow to warm . installed new therostat,controls,water pump
check the hearter control valve in line with the hoses also check to make sure the valve is working and opening if you have HOT! water on both sides of the lines and equal temp your heater core is plugged
Jan 15, 2010 | 1992 Ford Taurus
RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Dec 05, 2007 | Reddy R155D Utility Heater
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
