Question about Frigidaire Heating & Cooling
FC is coming in the display board why? - Frigidaire Heating & Cooling
If keypad displays the FC code Can you still program a new master code?
I have never tried that because it has never been requested. "FC" is a higher priority. It means failure to communicate. So I would always correct that problem first and then change the master code. But I don't see why you would not be able to change the master code due to FC code. Gl.
Jan 31, 2015 | Honeywell Ademco Vista 20p And 6150 Keypad...
GE RANGE DOOR LOCKED ON DISPLAY WITH FC ERROR
You might want to ask GE. They want customer satisfaction.
Nov 29, 2013 | Washing Machines
Beeps and flashes FC
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective.
Here is the part to order.
Jan 24, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
J SP420 NIBB GE oven Display reads FC locked door and oven will not work but stovetop works.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board.
You may need to get an appliance repair person out.
Mar 18, 2011 | GE Ovens
I am getting error message FC on oven control
FC Communication error between boards Wiring harness or power relay board (PRB)
Oct 28, 2009 | Jenn-Air JES9900BAS Stainless Steel Gas...
Tally T8106
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  • Power the printer on while holding down MENU/ENTER key
  • Release the key when the display shows "Utility Menu Clear FC. Roll"
  • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
  • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
  • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jan 28, 2008 | Tally T8106 Laser Printer
Error Message ('replace belt CG')
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Nov 23, 2006 | Thermador SMW272 Electric Double Oven
Heating & Cooling Logo
15 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
