Question about Zanussi Ovens
What is wrong with my oven the light wont go off
Zanussi ZOB140
2 Suggested Answers
mikadot
  • 2113 Answers
SOURCE: how do I wire my new zanussi zob140 integrated
http://www.electrolux-ui.com/2013/397/152501EN.pdf says it is shipped without a cable. It then lists cables that you can get.
Posted on Oct 23, 2013
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
How do I wire my new zanussi zob140 integrated oven? the manual indicates that it should be plugged in, but there is no wiring or plug to do so.
Oct 23, 2013 | Zanussi Ovens
Oven wont heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 06, 2011 | Zanussi Ovens
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
My oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
Sep 09, 2009 | Zanussi Ovens
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Zanussi zbf 760 (9 yrs old now)
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
Top Zanussi Ovens Experts
ashburton
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
