Question about Tappan Microwave Ovens
How can i repair my microwave oven with a model no.56-9832-10/01 that they plug in, in a 220V that the microwave is only 120V is the transformer damage? or other parts.Can you pls solve my problem
  • 86 Answers
Try to replace the ceramic fuse located inside. you have to open the cover first
Posted on Jun 23, 2009
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
Sep 21, 2017 | Goldstar Microwave Ovens
I have 110V AC, Sharp Household Microwave Oven, power transformer is damage. Is 220V AC transformer can be use as replacement?
NO. There should be a label on the part which has its part number, something like RTRN-A.......
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 01, 2017 | Sharp Microwave Ovens
GE microwave fuse model jes532wn rating 15v but what voltage rating: 120v or 240v ?.thanks
fuses do not have voltage ratings they are a current device. the 15 V does not make sense. It might be 15 A which is the current rating. A standing for Ampere which is the maximum current named after the discoverer of current creating magnetic fields being Andr?-Marie Amp?re in 1826. The 120v or 240v relates to the transformer design in the microwave. The transformer would be design to run on 240V AC 50 HZ AC like in Oz and UK or 120V 60 Hhz AC like used in the USA out of the power point from the power company.
Also the current relates to the voltage. So voltage divided by circuit resistance equals current.denoted by the formula I = V/R
Jan 24, 2015 | GE Microwave Ovens
If my current microwave unit is a 120v then can i replace it with a 220v without rewiring?
No, you would have to have a 220 volt outlet to be able to run a microwave of that voltage.
Sep 09, 2014 | Microwave Ovens
Hi I have GE Microwave (model no JES738WJ02) which has suddenly stopped working from yester day ... the problem is when I am starting it,the inside light gets on and the inside dish is rotating properly...
The easiest way to fix a problem at m.w. ovens is to check out if the 220V (Europe) volts feeds the transformer. You must remove the cover, put a glass of water inside the oven, turn on for 3 minutes and measure the tension that come to transformer.
Don't try to measure the transformer output, the tension is very high ~2400V !!!
If at the transformer input there are the 220V (Europe) but the oven still don't heat, the magnetron (m.w. generator) is burned out and must be changed.
Nov 14, 2017 | GE Microwave Ovens
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
This microwave oven plugged in 220V but the only volt for these microwave is only 120V how can you fix this?
Sorry - This may have done serious damage to the control logic.
This device will need professional repair and it may be cheaper to replace the oven.
Mar 25, 2010 | Sanyo EM-F300W Microwave Oven
Just replaced the magnetron in my Panasonic NN-S543BFR. I still don't get any heat from my oven. Everything works as set but still no heat in oven. Need suggestions on repairs.
When you say "Everything works as set" do you mean the microwave appears to function properly, but then doesn't heat?
If the magnetron is new, then the magnetron must not be receiving the required high voltage (2000V or more) from the HV circuit. Make sure you've got 120V to the PRIMARY (don't attempt to measure secondary voltage of the HV transformer without special equipment) of the HV transformer. After that check the HV capacitor and diodes. If these components test OK, then either your HV transformer is bad or your new magnetron is faulty. My experience is that the problem is usually in control circuitry, preventing 120V to the HV transformer, or opens/shorts in the HV components (diodes and capacitors).
Mar 15, 2010 | Panasonic NN-S543BFW Microwave Oven
There is little or no heating effect from the microwave
In all likelihood the mangnetron has failed, or perhaps even the Power Supply.
Feb 17, 2010 | Sunbeam SBM7500W Microwave Oven
THE INPUT IS 120V I CONNECT AT 220V
replace or repair control bord transformer
Apr 27, 2009 | Microwave Ovens
Microwave Ovens Logo
180 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
