Question about Garmin GPS
Tom tom pro 5150 no sound - Garmin GPS
Max hard drive that can be fitted to a dell dimension 5150 thanks tom
Sir your Dell dimension 5150 can be expanded with maximum 250 GB of hard drive .
Thanks.
Have great day.
Oct 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
TomTom Navigator 6 and HTC Touch Pro 2
Start
Settings
System
External GPS
Programs tab - select COM4
Hardware tab - GPS hardware port = (None), Baud rate = 4800
Access tab - Check the box for "Manage GPS Automatically"
Hit OK
Then open TomTom
Touch the signal bar then the signal bar again
OR
Go to Preferences then Show GPS status
Hit - Configure
Select - Other NMEA GPS receiver
Ensure the baud rate is set at 4800
hit Done
Select COM4:
Feb 16, 2010 | Computers & Internet
All lights flashing fast on HP 5150
Sounds like your DeskJet 5150 needs to be restarted. Try:
1) Press <Power> button to turn the printer off, then press again to turn it back on
2) If problem persists, turn off the printer
3) Disconnect the power cord from the power source
4) Reconnect the power cord
5) Turn the printer on
Dec 21, 2009 | HP DeskJet 5150 InkJet Printer
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
ACCESSING A NEW MAP
SOUNDS LIKE YOU DOWNLOADED IT TO TOM TOM HOME AND NOT TOM TOM ITSELF. OPEN UP TOM TOM HOME AND LOCATE THE US MAPS THEN THERE SOULD BE A OPTION TO TRANSFER MAP TO TOM TOM.
I HAVE ALSO 910 TOM TOM AND A PRO AT TOM TOM DEVICES
LET ME KNOW
Nov 23, 2007 | Tomtom GO 910
Dvd player produces no sound just picture.
tom, the issue is with expired codec of your player. This is a software level issue. Two solutions: 1. set your system date to Nov. 15, 2006, then try playing it again. or... 2. download the codec from http://www.free-codecs.com/K_Lite_Codec_Pack_download.htm ***this should solve your issue***
Dec 03, 2006 | Dell Dimension 5150 (DIM515MIN) PC Desktop
GPS Logo
19 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
