Question about MSI 865P Neo (MS-6742-020) Motherboard
Replacing existing DDR RAM
Which kind of DDR-SDRAM can I use with the MSI MS-6742 motherboard?
Is it possible to use anything else than PC1600 or PC2100?
TIA,
Peter
  • 400 Answers
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Posted on Jun 23, 2009
    Sergeant:
  • 220 Answers
Your motherboard has "avaliable bandwidth up to 2.7GB/s (DDR333) for single channel mode and 5.4 GB/s (DDR 333) for dual channel mode. (DDR 400 please refer to manual P.B-1 for more details)"
and "Supports Single or Dual Channel DDR 400/333/266 MHz"
That means that you can use almost every memory as long as it is DDR1.
Beware that your mobo only supports a maximum of 2GB ram, so using 512MB stick would be advised.
Cheers
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Computer starts up then shuts off
make sure you pushed the ram ships in all the way.also make sure that you didnt unhook anything from the mobo when you opened your computer.
Feb 19, 2009 | MSI P4MAM2-V Motherboard
Matching memory
Supported RAM Technology: DDR SDRAM
RAM Installed ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600.
If you have already replace it and its working good. not to worry about that.
Nov 30, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
MSI 865P Neo (MS-6742-020) Motherboard Logo
160 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
