Question about Microwave Ovens
Sharp r 310ck
Whats the wattage
Wattage of Sharp R-209HK
Power Output 800 W nominal of RF microwave energy (IEC Test procedure) per the manual at http://diagramas.diagramasde.com/otros/R209HPK.pdf
Aug 25, 2014 | Sharp Microwave Ovens
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
What wattage bulbs should be in the sharp model r-1610
According to the owner's manual (found online here) neither the interior nor cooktop bulbs should exceed 30 watts.
The original Sharp part number is RLMPTA068WRE0 if you'd like to order them.
You can get them Encompass here or Sears Parts Direct.
Jan 02, 2011 | Sharp Microwave Ovens
I have a sharp microwave-convection model #r-7a85. how many watts this oven needs or have thank you
800 or 1000 are standard wattages. It should say on the plate on the inside 'doorway' of your oven - that is where I find that info on my sharp microwave. It could be on the back but, like I say, normally inside the 'doorway' to the oven
Dec 27, 2009 | Sharp R-7A85 Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Wattage
Look on the back for the power requirements, them muliply the number of amps drawn times 100 . example 10 amps times 100 = approx 1000 watts, that will give you an approx. wattage. hope this helps
budman630
May 12, 2008 | Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
