Question about Ricoh Cameras
How to reset ricoh caplio dx 100 - Ricoh Cameras
SOURCE: Ricoh Caplio R4 Lens
I have the same problem and it seems that the Caplio R4 is prone to internal lens holder damage when dropped.
Looking around I found repairers that would charge £90 just for looking at the camera.
So I took it apart to see what the damage was. There are two lens (normal and macro) which swing down into position as the camera is started up and as the lens unit extends at the front of the camera.
The arm of the main lens in my camera has broken and the lens then dropped into the area in front of the receptor/pixel thing thus meaning that when the camera is turned off the external extending lens will no longer retract into the body. I might have a go at gluing the part back together but it looks doubtful
Posted on Oct 10, 2008
SOURCE: Ricoh Caplio R5 Digital camera
A SD-card will suffice. I have a SanDisk SD Ultra II which is really nifty since it also has a built-in USB-interface.
Posted on Nov 21, 2008
Fixe_You
  • 1800 Answers
SOURCE: Ricoh Caplio R3 zoom problem
the Zoom Cylinders is broken you need new ones
Posted on Jun 28, 2009
  • 126 Answers
SOURCE: software for Ricoh caplio R2 with snowleopard 10.6.1
Yes, on their website.....
Posted on Mar 26, 2010
  • 11967 Answers
SOURCE: lens stuck fully out will not reset
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 28, 2010
I want a user manual
The manual for the Ricoh Caplio G3 Digital Camera may be downloaded here:
http://www.ricoh.com/r_dc/caplio/g3/support/manual.html
Apr 21, 2012 | Ricoh Caplio G3 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
I lost my manual for an Caplio R1v? Can you send
http://www.ricoh.com/r_dc/caplio/r1v/support/manual.html
Nov 18, 2009 | Ricoh Caplio R1V Digital Camera
Jun 28, 2009 | Ricoh Caplio R4 Digital Camera
Caplio R7 error 30-01-23
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Ricoh Caplio GX Digital Camera
Not many but a FUJIFILM 1 gb card will do the trick
Nov 26, 2007 | Ricoh Caplio R5 Digital Camera
Ricoh caplio R5 digital camera
Flash not working Reset the ISO setting to a higher number Invest in a good image editor or even download the free Picasa
Aug 02, 2007 | Ricoh Caplio R5 Digital Camera
Cameras Logo
26 people viewed this question
Top Ricoh Cameras Experts
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
