Question about Dishwashers
Why does my Kelvinator kd12dss-2 dishwasher give an error code 2
3 Suggested Answers
jnchahn
  • 252 Answers
SOURCE: We have an Error 4
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
Posted on May 13, 2011
ginko
  • 19396 Answers
SOURCE: The kelvinator kd12dss-2 gives an
Hi.
Error 4 is internal leakage (overflow).
when this happens often the dishwasher starts with the pump running continuously.
Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
Regards.
Ginko
Posted on May 28, 2011
I have just reeived a Kelvinator dishwasher KD12WW. I have only a cold water outlet can I still wash with it
I found a site that is important for you to down load the site is ns323666.ip-37-187-156.eu
It is a pdf version of the instruction manual for the dishwasher
I notice that one of the instructions is quote" when using your dishwasher , you should prevent plastic items from contacting the heating element" un quote
most all dishwashers heat their own water above what human hands can stand so from that statement you can use cold water inlet only and the machine will heat it to operating temperature
I got that site by going google and typing in --kelvinator kd12ww dishwasher
then I selected site manual-kelvinator kd12ww dishwasher clicked on that and that address came up with the pdf manual
there are other sites that have parts manuals and heaps of other information
call your local kelvinator service agent and ask them about a heating element
Sep 30, 2016 | Kelvinator Dishwashers
Why are two brand new dishwashers giving me the same error?
as it is under warranty I would have the service agent back again and this time either fix the machine properly or replace it under the terms of the warranty or get a refund of the purchase price for the machine
it is obviously not fit for the purpose if two machines do the same thing
one thing to be aware of, if the elements are not getting hot enough, it may be advisable to check the power voltage into the machine at the power point as the mains voltage may be too low for the elements.
May 14, 2015 | Kelvinator Dishwashers
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
A KD12DSS-2 KELVINATOR DISHWASHER WITH FAULTY ERROR 4 CODE
Hi.
Regards.
Ginko
May 15, 2011 | Watches
We have an Error 4 on our KD12DSS-2 Kelvinator Dishwasher, the manual says that there is to much water in the machine, how do i go about cleaning it out, so the error can go away?
May 13, 2011 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
