Question about Canon PIXMA MP600 all-In-One InkJet Printer
I inserted new toner cartrigdes for the blue and pink toners. The light didn't light up once they were clicked in. I returned the toners to the store exchanging them for 2 new toners. These also are not lighting up when clicked in, and the printer says they're not recognized. I didn't touch the metal portion on either the toners or the printer so there was no interference with the current. I turned the printer on and off a couple of times to re-set it and it still doesn't recognize the new toners. What else can I do to get the printer to acknowledge that two new toners are in place? I had no problem when I replaced the black toner. Thanks
    Champion:
  • 236 Answers
First make sure the cartridges are EXACTLY for your printer model. Sometimes the chips dont make contact even though they seem to be in place - FIRMLY place them in CORRECT slots.
Posted on May 17, 2014
    New Friend:
  • 12 Answers
Are these Canon original cartridges or knock-offs?
WMT
Posted on May 12, 2014
Kyocera 1620 Error code E 32
that code means that the toner cartridge is not inserted far enough to make the switch behind toner cartridge. check blue handle that latches the toner cartridge. make sure its not working loose. i had this once and replaced the toner cartridge and never had code come back.
Mar 06, 2018 | Kyocera Office Equipment & Supplies
Drum error
Hi, the drum is the part where you insert the new cartridge toner, some times when you replace the toner need to clean the small filament in the drum unit, is very simple, ther is a blue part, slide 2 o 3 times and return to his original position marked with a arrow, maybe this solve your problem,9436fabb-a042-4f75-962b-c59ad843e6bb.jpg
Sep 17, 2013 | Brother HL 2140 Laser Printer
How do you change the cartridge? i am having difficulty removing it.
hi,
you open the front door and pull out the toner cartridge/drum. when you open the door there is a little handle on the left that unrestricts the cartridge from coming out. once its out, you push a button, (there may be 2) on the right side and possibly left, you push them down to separate the toner from the drum
thanks
Sep 01, 2010 | Brother HL-2040 Laser Printer
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
How do u chang the ink cartridge?
1. Openthe front cover and pull out the drum unit. Place the drum unit on a drop clothor large piece of disposable paper to avoid spilling and scattering the toner.
2. Holddown the lock lever on the right and pull the toner cartridge out of the drumunit. Handle the toner cartridge carefully. If toner scatters on your hands or clothes,immediately wipe it off or wash it with cold water.
3. Unpack the new toner cartridge.Place the used toner cartridge into the aluminum bag and discard it accordingto local Regulations.
4. Gently rock the toner cartridgefrom side to side five or six times. To distribute the toner evenly inside thecartridge.
5. Remove the protective cover.
6. Insert the new toner cartridge inthe drum unit until it clicks into place. If you put it in properly, the locklever will lift automatically.
7. Clean the primary corona wire inside the drum unitby gently sliding the blue tab from right to left several times. Return the Bluetab to the Home position () before reinstalling the drum Unitand toner cartridge assembly.
8. Reinstall the drum unit and tonercartridge assembly and close the front cover.
Feb 26, 2009 | Brother IntelliFAX 4100 Laser Fax
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Malfunction detected c2557
This is a problem whit the black toner make sure there is toner left and that the cartrigde opens when you insert it in the copier. try to remove the tape covering the tonerpipe on the backside of the toner cartridge.
Nov 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Toner light will not go off
Take the drum/toner out and with the front cover open press the blue 'go' button once, then put the drum/toner back in and press the button once again, then close the cover.
should reset the toner for you
Nov 10, 2008 | Brother HL-5240 Laser Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
