Question about Bosch Classixx KGV24323 Bottom Freezer Refrigerator
What is teh red light switch for - Bosch Classixx KGV24323 Bottom Freezer Refrigerator
Front blower motor will not work in 1994 f 350 van all fuses are good no power anywhere (at switch, resistor, or blower motor in any position
check the 50 amp fuse in teh engine compartment fuse/realy box. Also check the blower motor relay that the fuse protects.
Alos, check fuse 9, 15 amp in fuse panel in truck.
Test by applying 12 volts to teh orange/red wire at teh blower motor connector. Use a 10 or 12 gauge wire with a 25 or 30 amp fuse in line.
report back
Jan 11, 2011 | 2002 Ford E350
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
My 1996 taurus has the brake lights constantly on. when you disconnect the switch by teh brake pedal the car will not shift out of park but teh brake lights turn off???
CHECK BRAKE LIGHT SWITCH TO SEE IF ITS TOUCHING THE BRAKE PEDAL.IF BRAKE LIGHT SWITCH OR BRACKET LOOSE AND AWAY FROM BRAKE PEDAL BRAKE LIGHT WILL STAY ON.IF BRAKE LIGHT SWITCH INTACT BRAKE LIGHT SWITCH NEED REPLACING.WHEN REPLACING BRAKE LIGHT SWITCH OR IT NEEDS ADJUSTING MAKE SURE BRAKE LIGHT SWITCH PLUNGER TOUCHES BRAKE PEDAL ARM WHEN YOU RELEASE BRAKE PEDAL BRAKE LIGHTS SHOULD TURN OFF.
Sep 01, 2010 | 1996 Ford Taurus
Compaq presario sr1010v power light blinking
Try disconnecting the A/C source.
Allow unit to set for 5 minutes.
Re-install power and restart uint.
If that does not work, Disconnect power and remover supply connections at the motherboard.
Allow to set for afew minutes, and re-connect.
Sometime, removing the connections at the motherboard, allows the supply to reset.
You should have a 4 pin video connection and a 24 pin main board connection.
Note. Make sure your power is disconnected before attempting this service.
Sep 29, 2009 | HP Compaq Presario SR1010V (568656) PC...
MLX-10DP phone thinks there's a headset plugged into it
Try a different phone. The clicker switch could be bad on teh phone.
Jun 24, 2009 | Lucent Merlin Legend MLX-20L Phone
Ice build up in freezor compartment , on food and in ice bin
the defrost heater may be open (not shorted) Most time the defrost heater lamp has failed. It is behind the panel in the rear of the freezer.
Apr 23, 2009 | KitchenAid KSBS25FK Side by Side...
Replacing cd-rom
u need open the cabinet and there should be a serew and remove it and connect teh new one and make sure teh power and date cable the red side of teh power as well as the red side on teh data cable should face same side and start the pc>and put the cd and install soft ware and start using teh dvd and cd>rate me solved if its helps thx
Nov 16, 2007 | HP Compaq dc5100 PC Desktop
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
Bosch Classixx KGV24323 Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
