Question about Health & Beauty
I have a invacare taurus. . When I plug charger in the fan works for about 2 seconds then stops?? Won't come on unless I unplug but goes off after 2 seconds again? Any help please
  • rich newman May 14, 2014
    Red light is on the charger.
    Amber light comes on then straight back off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
There are a lot of possibilities here. The most likely is that the batteries are too low. If the battery voltage is TOO low, then the so-called 'smart charger' won't even 'see' any batteries to charge.
This usually means old or dead batteries, but if they just got low somehow but are otherwise OK, try using a car battery charger to slow-charge them (one at a time) back at least where your charger can see them.
Posted on May 30, 2014
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Why is insufficient power getting to controller?
David,
have someone check the freewheel handles are in drive position, then unplug charger.
Jan 22, 2016 | Invacare Pronto M51 Power Wheelchair
How do I get my pronto m91 out of charging mode?
The M91 has an onboard charger. When unplugging the charger power cord from the wall outlet does not stop the chair from being in the charge mode, The charger has to be unplugged from the wheelchair wiring harness or main control module under the plastic body parts. The on-board chargers fail like this sometimes.
Jun 06, 2014 | Invacare Supply Group Invacare Pronto M91...
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
Hello, i have a invacare wheelchair that has 2 12v sealed batteries, wired in series at 24v. I wanted to find out the charge plug has 3 prongs, which should be -. ground, . over vice versa, how come there...
Salty The charger detects the batteries when it is plugged into the charger port. With the older chargers you could measure the output of the charger by measuring across the two outter pins. With the newer chargers there is no output until the charger is plugged into the charger port. Now on the M51 you should have an on-board charger and the cord plugs into the back of the chair into a three pronged plug. Now if you plug the on-board charger into the wall socket and look at the rear of the chair low to the ground you should be able to see a red and yellow light (red and green when fully charged). With this charger plugged in you can take a digital voltmeter set it on 200 v dc and plug the leads into the two outter holes in the charger port under the front of the joystick you should read 27-30 volts when charging and 24-27 volts fully charged and the charger unplugged. Hope this helps you
Sep 20, 2010 | Invacare Pronto M51 Power Wheelchair
My invacare pronto m51 wheelchair does not turn on. we just had the battery replaced. when it is plugged in the battery lights turn on and when you unplug it they do not even turn on.
Did you replace both batteries? How old is the chair? Sometimes the on-off keypad becomes worn and does not make contact with the on-off switch. When charging the joystick lights can light up but after unplugging they should remain on. When you plug in the charger look under the rear cover at the charger you should see 2 lights, one red and one yellow to indicate that you are charging the chair if you do not see both lights lit then the charger is bad or has a blown fuse. Only a Tech will be able to tell what is wrong. If Medicare purchased your chair then they will pay for most of repair costs. Contact your provider or a repair service company
Aug 16, 2010 | Invacare Pronto M51 Power Wheelchair
Heater blowing good heat temp gauge not moving and cooling fans not coming on. Unplug engine temp sensor and fans start put plug back on fans stop. gauge never moves
bad gauge or bad thermostat.
Fans come on because when you disconnect, it goes to default mode of fans on high speed.
Feb 19, 2010 | 2002 Ford Taurus
Health & Beauty Logo
42 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
