Question about Kelvinator Dishwashers
Kelvinator kd12dss-2 error code 2
What does this error code means and what needs to be replaced please
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: The kelvinator kd12dss-2 gives an
Hi.
Error 4 is internal leakage (overflow).
when this happens often the dishwasher starts with the pump running continuously.
Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
Regards.
Ginko
Posted on May 28, 2011
Error code 5 on kelvinator KL55DFL
This code mean the control board or timer or clock has failed.
Feb 04, 2015 | Washing Machines
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
WHAT DOES "E5" error code means? I've got a KELVINATOR KTD600MD T/DRYER
water not been filled quick enough have you made sure the water is turn on fully and check the filter they get clogged up
Sep 12, 2013 | Smeg WDI12 Front Load Washer / Dryer
A KD12DSS-2 KELVINATOR DISHWASHER WITH FAULTY ERROR 4 CODE
Hi.
Regards.
Ginko
May 15, 2011 | Watches
We have an Error 4 on our KD12DSS-2 Kelvinator Dishwasher, the manual says that there is to much water in the machine, how do i go about cleaning it out, so the error can go away?
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
May 13, 2011 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Kelvinator Dishwashers Experts
P Scarbs
Level 1 Expert
paul
paul
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
