Question about Epson TM-T88IV Printer
Epson tm-t88iv thermal paper size - Epson TM-T88IV Printer
lgc999
  • 39 Answers
SOURCE: EPSON TM T88IV THERMAL PRINTER
how is the printer connected? usb, parallel, network, etc?
Posted on Nov 02, 2007
Nitrotrike
  • 589 Answers
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Posted on Jan 14, 2008
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
Posted on May 16, 2008
ohms
  • 1879 Answers
SOURCE: tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Posted on Mar 06, 2009
  • 310 Answers
SOURCE: the error light on the Epson TM-T88IV keeps
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Posted on Oct 23, 2009
Could you please assist me by identifying the ink code or serial number for Epson Tm-t88iv please? Urgent..
Felix, Are you sure this uses ink ?
It might be a thermal paper roll and will need thermal paper for it to print.
I think RPT3.125-STD is the thermal paper for this printer
inserted the correct side also.
Feb 21, 2017 | Epson Office Equipment & Supplies
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
What can i do to enable my printer's beep in windows 7
Have you installed the windows 7 driver obtained feom epson comany?
support.epson.com
Jun 30, 2014 | Epson TM-T88IV Thermal Printer -...
What should I do, to not have much paper loss?
can u try printer with standalone pc
or with another single pc
My epson TM-T88IV printer is not working... I printed a self test which says "buffer is full"...?what does that means and what should i do now
it sounds like the ram on the epson has gone bad... contact epson support tell them about the buffer and ask if you need to change the internal ram on the epson...
Dec 24, 2009 | Epson TM-T88IV Thermal Printer -...
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
EPSON TM T88IV
May 14, 2008 | Epson Stylus C66 Photo InkJet Printer
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
