Question about Miller Welding Tools
Turbo hydramatic 350 troubleshooting
How to find the age of a machine
2 Suggested Answers
  • 2002 Answers
SOURCE: Pontiac Parisienne
It should be a bolt-in. Check the overall length of the new transmission against the length of the old one. Sometimes the tail shaft can be different lengths and that may mean you will need a different driveshaft. If the difference is an inch or less you should be okay. Hope this helps.
Posted on Jan 22, 2010
95 jeep Cherokee parts interchanges with a 1989 thru 1995 chevy 4x4 silverado
another 350 hydramatic turbo transmission would be the simplest change out . Interchanging with different transmission can become a very costly exercise
MY question is have you had the problem properly diagnosed by an accredited transmission shop or are you just going on the recommendation of a local mechanic that the transmission is shot and you need a new one
From your description it could be servo/solenoid or band and clutch adjustments
Have you had an oil pressure test done , had the oil changed
All that I have suggested can be done in car by an accredited shop
Feb 27, 2017 | Jeep Cars & Trucks
I have a 92 GMC , 350 engine. I have no reverse and no overdrive. Any suggestions ?
I'm suspecting a 350 turbo hydramatic tranny. Pull the tranny stick inspect the fluid color and level. If fluid is brown/black and smells burned, the tranny needs an overhaul. If fluid level ok and color reddish, I would suspect a clutch issue and the tranny will require further diagnostics/repair
Jun 06, 2015 | GMC Cars & Trucks
Will a 454 turbo transmission bolt to a 350 big block engine?
yeah this will work....most 350 big blocks come with either a 350, 350 turbo or 400 turbo transmissions.....bolt pattern is the same
Sep 13, 2014 | Cars & Trucks
700r4 trans in 92 gmc truck stays in overdrive all gears
Sorry to say this, but the 700r4 was a piece of junk. You can have it rebuilt. If memory serves you can replace it with a 350 or 400 hydramatic
Aug 28, 2012 | 1992 Chevrolet K1500
Truck rolls backward in park..runs and shifts fine just no true park
sounds like the parking pinn or [pawl] Inspect the parking pawl as it is likely broken. The pawl is a metal pin that engages the transmission's gear when the transmission is in the "Park" position. The pawl manually locks the transmission's gears and is located on the interior side of the transmission's manual control linkage
Read more: How Do I Troubleshoot a 1968 Chevy Hydramatic 400 Transmission? ' eHow.com http://www.ehow.com/how_6940725_do-chevy-hydramatic-400-transmission_.html#ixzz1OKEuCICo i know this says chevy but should be the same type of operation.. i hope this helps you
Jun 04, 2011 | 1989 Ford F 150
Pontiac Parisienne
Jan 22, 2010 | 1984 Pontiac Parisienne
What kind of transmission in 1987 pace arrow 454 engine
it may be a hydramatic turbo 400 during those years.
Jan 18, 2010 | GMC C3500 Cars & Trucks
4l80e transmission interchange
700 r4 same tailshaft as 4l80 e . Also you can use any turbo hydramatic if you modify driveshaft
Jan 06, 2010 | 1995 Chevrolet Silverado 2500
I want to replace powerglide with turbohydro in 66 chevy 327 impa
You just need to Locate one from a 350 Chevy. They have the Same Bolt Pattern.
Jan 04, 2009 | Chevrolet Impala Cars & Trucks
Changing 3.1 with 350 turbo
guess what, you have to buy a conversion kit.. or make one... had the same issues when i put a turbo 350 trans on my 85 camaro.... came stock with the 700r4
Dec 13, 2008 | 1992 Chevrolet Camaro
Welding Tools Logo
62 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
