Question about Morphy Richards 43691 Cordless Electric Kettle
Why my kettle not boiling ? - Morphy Richards 43691 Cordless Electric Kettle
Wont cut off when boiled
Is the kettle lid fully down? If not then the sensor won't get hot enough to activate the power cut off sequence. If all this is OK then consider junking the kettle for a new one. Obviously, if you are attached to kettle then take it to a reputable repairer. If the kettle is a fairly cheap one he should suggest replacing it.
Apr 02, 2015 | Kitchen Appliances - Others
Russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
Mar 13, 2011 | Kitchen Appliances - Others
I bought the Russell Hobbs Whisper Kettle expecting it to boil quietly. Wrong. It is quite the opposite. Not sure if I can take it back due to "false advertising"??
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
Feb 23, 2011 | Russell Hobbs RHOK3123 Cordless Electric...
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
Oct 25, 2008 | Faberware FCP512S Cordless Electric Kettle
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Morphy Richards 43691 Cordless Electric Kettle Logo
127 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Ruth summersides
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
