Question about Microwave Ovens
Seiki model se 322fs shows no picture!!! - Microwave Ovens
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
Feb 01, 2016 | Maytag MMV4203D Microwave Oven
I have a SamSung microwave that keeps beeping SE on display
"SE" means you have a shorting membrane keypad.
On some models, the membrane keypad itself is replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is not available as a separate part, so you have to order either the control panel frame assembly (which has a new keypad on it) or a whole new controller assembly / control box.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
Jan 29, 2013 | Microwave Ovens
How do i fix the se on a micro wave
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 16, 2013 | Maytag Microwave Ovens
What is the symbol --se-- on a amana serial number1000001gt radarange microwave oven mean
Jan 16, 2013 | Amana Radarange Microwave Oven
Samsung microwave says-SE- but won't respond otherwise
Jan 15, 2013 | LG LMVM1935 Convection/Microwave Oven
MY MICROWAVE DOSENT DO ANY THING IT ONLY SHOWS THIS ON SCREAN -SE-?
"SE" is the Samsung code for a failed membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
On some models, the keypad is available as a separate part.
If that's your situation and you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models, the keypad is not available as a separate part, so you'd have to order so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 15, 2011 | Samsung Microwave Ovens
Shows SE on display . nothing else will work on controll panel, Please help can't figure out what happened.
"SE" means that your membrane keypad has shorted.
You can order parts by entering your full model number here. The membrane is reference number 25 on the control panel parts list.
If you need further assistance, or would like to replace this for you, please let us know.
Jan 23, 2011 | Tappan TMS062E1 Microwave Oven
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
The model is FMV158FMB. What does the code SE
SE error means you have a shorted membrane keypad (called a membrane switch in this case).
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 09, 2010 | Frigidaire FMV156DC Microwave Oven
Tappan microwave shows error code SE
The SE error means you have a shorted keypad.
There should also be a "mini-manual" hidden inside the unit ehind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
Aug 07, 2008 | Tappan Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
