Question about Cell Phones
What do you mean by forwarding on conditional on?
  • 63 Answers
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
Posted on May 12, 2014
I own a 2000 Nissan Frontier 4X4. I have not had occasion to use the 4 wheel drive. Can you tell me how to put the truck in 4 wheel drive and take it out? Do not have a manual. Thanks!
Assuming yours is the 2 gear stick layout this is roughly how it works.
ONLY CHANGE BETWEEN 2 AND 4 WHEEL DRIVE WHEN STOPPED, IN NEUTRAL AND WITH THE PARKING BRAKE ON!!
The smaller gear shift should be to the left of the normal gearstick.
It should be in the fully forward position. This means it is in 2 wheel drive, high ratio, for normal road driving. (Rear wheels).
Pulling the stick back ONE notch engages 4 wheel drive, high ratio. Used for snowy, icy, slippery conditions as well as light off roading. (Keep the speed under 50mph).
Pushing down and back another notch engages neutral in the transfer box. This means ALL drive is DISCONNECTED even if you use the normal gearbox.
**Try to avoid this one**!!
Pulling the stick back the last notch engages 4 wheel drive, LOW ratio. This is for the more extreme off roading conditions such as VERY steep hills. Not usually used in normal day to day driving.
The two fully forward positions, (2High and 4High), will be the ones used the most.
Jan 15, 2018 | Nissan Cars & Trucks
Bmw312i 2004. Lost forward power. Car went well until stopped on hill at lights would not go forward backed back to flat. Started very slow and then went ok
Without any further info, it sounds like a transmission fluid issue.
If it was running fine when level and started acting up while in an incline, you may not have sufficient transmission fluid in the transmission.
The fact that it started to move slowly then went ok once level is an indication. If you continue to drive in this condition, you could damage your transmission.
You should have your fluid checked (some of these newer transmission are 'sealed', meaning there is no 'dipstick', but any competent shop can check the level and the condition of the oil)
Are you the original owner? If you bought it used, you may have uncovered the reason for selling, which I've heard can be temporarily masked by using additives, etc.
Any major transmission repair is going to be expensive...2~3 k
May 09, 2017 | BMW Cars & Trucks
Conditional forwarding activated
it means dat other calls will be diverted
Apr 10, 2012 | Cell Phones
Car will not go into any forward gears only reverse. aotomatic trans.
check ATF condition (burn , black coler ) most of same case means clutch for forward is damage try to replace torqu.covertor if not replace complete trans..
Jun 23, 2011 | Volkswagen Jetta Cars & Trucks
I have a 1998 Oldsmobile Bravada auto trans drive works fine but no reverse
Are you sure you have all 4 forward gears? Most of the time a no reverse condition also means 1st and 3rd only.No 2nd or 4th.If you dont have all the forward gears as i suspect , the reaction shell is stripped or broken.If you do have all the forward gears then these are the two most common reasons you do not have reverse.1 reverse input clutches are damaged or burnt 2 forward cltches have slipped to the point they are welded together causing a mechanical bind in reverse and also causing the transmission to pull forward in neutral.Let me know if i can help.Good Luck.
Feb 28, 2011 | 1999 Oldsmobile Bravada
I have samsung champ and there it shows me conditional forwarding activated whike making a call how can i remove that pls help
This just means that people who call you while your making a call will be diverted to your voicemail.
This is standard practice. BUT Settings, Call settings, Call forwarding, and then there should be an option to disable all call forwarding options.
Dan
Jan 14, 2011 | Samsung SGH-D900 Cellular Phone
Conditional forwarding?
everytime i make a call
it keep popping up conditional forwarding calls
how do i cancel/
Aug 26, 2009 | Cell Phones
Phone disconnects shortly after dialing.  says" conditional forwarding"  then "call ended"
Call you cellular provider and sk for codes to disable conditional call forwarding, it should be something like *772
Dec 09, 2008 | Cell Phones
Cell Phones Logo
159 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
