Question about Beko Dishwashers
Door won't close
Been working fine now door wont close as far as the catch, have looked for anything obviously obstructing the door but cant see anything.
  • 9 Answers
SOURCE: Dishwasher door not catching
that is the spring thats gone and will not lock the jaws you need to replace the lock on the door normaly about£5.00
Posted on Dec 06, 2007
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
  • 28 Answers
SOURCE: Indesit IDL500 door wont close properly, catch
A lever inside the door lock is attached to a spring. If the lever or spring is broken, it wont lock.
Posted on Jul 27, 2009
SOURCE: indesit dishwasher
On a D61 I managed to solve this without dismantling the door!
If you look carefully in the hole where the white catch fits you can see the shaft it rocks on. I put a small screwdriver in here and levered it forwards. It didn't want to stay so I put another screwdriver behind the white plastic bit, removed the original screwdriver, and continued to prise the white plastic bit forward until it clicked and stayed. I reckon it is caused by slamming the door. Don
Posted on Apr 04, 2010
  • 15 Answers
SOURCE: My door doesn't seal/catch when closing. Machine
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Posted on Apr 29, 2010
Testimonial: "Thank you , we will try this."
What causes erratic hatch opening and closing?
Hi Robin, Im AL the owner of Big As Auto Repair.
Robin, it sounds like you have something binding in the motor assembly. You see anything that catches and causes a restriction in the movement of the door closing are opening will cause the door to reverse. If you see anything touching the door or the props that hold the door open move the obstruction and it should work properly. If you do not see anything, then the most likely cause is the gear and motor assembly. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Jan 18, 2016 | Cars & Trucks
92 Honda accord drivers side door won't open. And
IF DOOR WONT OPEN FROM INSIDE THEN IF YOU LIVE UP NORTH RUST IS PROBLEM.....TAKE A FUNNEL POUR BRAKE FLUID WHERE THE LATCH IS....WAIT 1-2 DAYS AND DOOR WILL OPEN.....SHORT TERM FIX
May 23, 2012 | 1992 Honda Accord
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
My kenmore elite with digital face wont start. just beeps when you hit the start button
If the washer beeps when you are trying to start a cycle, the control believes the door is open.
First of all check the hinge area, the door seal and latch/catch area to make sure something is not in the way of the door being fully closed. If it is closing fine and nothing is obstructing, you will most likely need to have the door latch mechanism replaced. If you can send me the full model number from inside the door I can get you an idea of what this might cost.
May 03, 2010 | Washing Machines
2006 slider door latch problems
make sure the latch is open, use a screw driver, stick it in the middle of latch where the striker would latch the door, now open handle as if your opening the door hold handle in that position and pull screwdriver out slide away from door to open the latch,latch might have closed it self, try that first, hope this helps.
Dec 06, 2009 | 2006 Kia Sedona
2005 passenger power sliding door problem
Check the track to make sure there isn't anything obstucting it. This might sound obvious, but you never know.
May 28, 2009 | 2004 Toyota Sienna
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
The refridgerator door of my Whirlpool side by side refridgerator/freezer is not closing properly. I checked for any obstructions including possible deterioration of the magnetic strips. It acts like the...
look closly at bottom of door there is a metal door stop, screwed to bottom of door, that prevents door from opein too far. Well when the door is forced open too far the door stopbends sdn then actually prevents door from closing all the way, you see it hitting the hinge(if indeed this is your issue), to repair it either simply bend it back staight witha pair of pliers, or what i sometimes do is switch the refrig and freezer door stops.They are identical, but only require the use of one side, (1 stop will do either door just depends on position as to how it operates)
Mar 09, 2008 | Refrigerators
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
22 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
