Question about Gateway N214 Laptop
How can I increase the memory card size in my son's Gateway N214, model no. NAV50 with 1 gig of memory. Can I increase the memory in this computer? Does it have only 1 memory card in it? I have a 2G card: ID# CT25664AC667.16FE 2BD 200 PIN DDR2 SODIUM 258Mx64 and it has one more number on it: BP112ZG.5H and a couple of numbers by the bar codes. Any idea if I can add it or swap out the other card? Is it the wrong kind of card?
marked
  • 6487 Answers
SOURCE: Cannot upgrade memory on my Gateway MX3215
Yes this laptop can hold 1 GIG of RAM and that should using this type of RAM SODIMM (PC4300), if you still have the same problem try upgrading first using 2 piece of 256MB or 2 piece of 512 MB so we can see it will be working fine on those capacity....
Posted on Aug 20, 2009
  • 2567 Answers
SOURCE: I need the size or model number for a replacement
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Posted on Sep 08, 2010
  • 1542 Answers
SOURCE: Gateway MA2A. I need
Hi
If you click on this link
www.crucial.com go to the scanner click on it then go to the top of the screen and allow the download
the scanner will scan your laptop and tell you what you have installed
how many slots you have and how much you can put in there
good luck
hope you get sorted
Posted on Feb 19, 2011
SOURCE: I just bought a Gateway Netbook model number
see this link: http://blog.whyztech.com/2011/01/upgraded-gateway-lt25-netbook-ram/
Posted on Mar 05, 2011
Xenturion
  • 68 Answers
SOURCE: upgrade video card or increase video memory on a
Unfortunately, there isn't any way to increase the video performance of this model. Only very few laptops have interchangeable video cards and this isn't one of them, sadly. Video RAM can sometimes be increased in the BIOS by hitting F2 when the computer is first starting up (during the Gateway screen) and fiddling around with that, but it's probably a long shot because usually only enthusiast laptops have that function.
Posted on Aug 24, 2011
Can i increase the main memory space in fujitsu LH531 model ??
If you have 4 gig's in it now...no. Otherwise you can put up to 4 gig in it.
Jun 20, 2015 | Fujitsu Lh531-b960 Laptop 14hd...
Whay are the power lights flashing?
I don't believe there is a N214 Gateway.
Jul 09, 2014 | Gateway N214 Laptop
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Upgrade video card or increase video memory on a gateway NV53a
Aug 23, 2011 | Gateway NV53A24u Laptop
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
How do I install more memory in a Gateway GT5464?
Please look into the below link for user guide manual to install Memory into your computer:
Refer to page no: 37: To Install or replace DIMM memory.
Here is the link:
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Regards,
Shami
Dec 03, 2010 | Gateway Computers & Internet
How can I increase the memory for this computer
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
Hy s my card not working in my samsung r451c phone but it does in my lg phone
Check the Samsung Manual, for max size memory card. certain models can only take up to a certain gig size, if this is ths case, get a smaller card for the fone
Feb 21, 2010 | SanDisk 2GB microSD Memory Card
My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot...
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Feb 07, 2010 | Computers & Internet
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Gateway N214 Laptop Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
