Question about Hilti Hammering
How to get wrench light to stop blinking and gun working again?
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
I have the titanium 1/2 impact gun and in foward or reverse the gun some times stops working and just blows air like a bad o-ring but i really dont know thanks
The vanes in the air motor are worn. There is a flat spring that pushes the vanes against the cylinder to maintain a seal... They go weak after a while
Aug 15, 2011 | Ingersoll Rand 2135PTI Pneumatic Titanium...
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Jan 09, 2011 | RTO Paslode #650027 2500CT Placement Nail
My paslode impulse framing nailer quit working. It fired and the fan shut of prematurely then it would not fire and the fand would not run. The blinking green LED light in the handle is blinking green...
It sounds like the contacts in the plunger are dirty or bad. Or even a wire for the contacts is loose. My guess is when you took it apart to clean it and replace the Orings you had moved the loose connection so it worked for a minute. On mine, I went all through the gun only to discover the wire feeding through the gas chamber was squished and broken inside. The wire's plastic insulation did not even have a hole in it. If you take it apart again check the wires carefully, check the contact points to make sure they are clean as well.
Another note, my father had issues with his and we went through it with a fine tooth comb. In the end we discovered it was a dirty contact in the gun where his battery hit. The battery itself was fine but once we cleaned the batteries terminals with a pencil eraser and plugged it into the gun we noticed one of the contacts had black stuff on it from the contact inside the gun. Works great every since.
Nov 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Husky Grease gun h4424 not working right
It sounds like you are getting air in the grease, anyway that happens to me sometimes when I don't have it full of grease where the cartrige screws in (and i change cartriges). Try it with the part where the cartrige screws on clear full of grease & top of cartrige with grease on it. See if that works. Rick
Apr 10, 2009 | Air Tools & Compressors
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
MY tV will not power and red light keeps blinking
i had the same problem with my tv i got a sodering gun its the board like the power supply open the tv and look on the board and look for ic801 on the bottom of the tv board then look in box line it has numbers from 1-7 get a sodering gun then soder number 4 i tryd it it worked on the board but be care full it will mess up quick if your not i had the same problem with this tv the soder on the board probly came off on no.4 but after your done and you have to pick the tv up becareful and do it slow because number 4 might come off again then you have to do it again and if that aint it just look on the bottom of the board and make shore nothing is loose and use the sodering gun to put back on that should be it ok then
Dec 19, 2007 | Panasonic CT-32SL14 32" TV
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue...
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Aug 21, 2007 | Sony KV-35S36 35" TV
Hammering Logo
99 people viewed this question
Top Hilti Hammering Experts
Todd Arndt
Todd Arndt
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hilti Hammering Expert? Answer questions, earn points and help others
