Question about Mtd Garden
Why does my Honda G200 197 slow down under load?
It runs OK, but when tackling thick coarse grass it struggles to keep running, I then have to increase the revs, back off and go in gently.
    Champion:
  • 279 Answers
If the engine doesn't need a tune-up, then you need to sharpen the blade.
Posted on Dec 22, 2014
canbruce75
  • 1776 Answers
SOURCE: Racing of a Honda 160 CC lawn mower engine
When a small engine "surges" in all speed ranges the possible causes are:
*Dirty air filter
*Water or contamination in the fuel system.
*Breaks in the spark plug wire (leaking), loose or corroded terminal connections causing an intermittent failure.
*Misadjusted or malfunctioning governor.
Problems with surging only when under load or at idle are likely caused by carb blockage or misadjustment.
Hope this helped and good luck to ya!
Posted on Jul 20, 2009
  • 93 Answers
SOURCE: mountfield 4.5hp briggs starts ok
Replace Spark Plug, Check for Rust on the Flywheel and clean with wire brush, also clean coil (Flywheel end).
Posted on Sep 15, 2009
  • 15 Answers
SOURCE: Poulan pro 20hp 42" lawn mower running rough
My immediate impression is that the float is "stuck open".
Pull the float-bowl, and check that:
a. the bowl and float are clean, and
b. the float moves freely, and
c. when it's in the "up" position, the flow of gas stops (which means that the needle is "seating" properly and doing its job)
Posted on Sep 27, 2009
  • 78 Answers
SOURCE: Lawn Mower Starts, Runs at Idle Smoothly, but it will not kick up
Ok it need a governor adjustment,depending on the brand of engine, there should be a tab with a spring attached. U need to bend the tab slightly to increase the rpms.
Posted on Oct 29, 2009
SOURCE: Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Posted on Aug 01, 2010
Kawasaki 341cc runs bad under load
Possible fuel system issues or misfiring
Jun 30, 2017 | Computers & Internet
Engine runs rough under load
how old is the motor
4 stroke with valves or a two stroke ?
blades
spark plug , coil , air fuel mix check valves
re check governor setting
if grass is way above the front height of the frame it will struggle
raise the height first to max on the first run
then lower
or use a grass trimmer to knock the level down before mowing
May 17, 2016 | Garden
It starts and runs for a bit but as soon as it hits thicker grass it dies
Joe Hi there. Sadly your trimmer will struggle on thick grass as it's not made for it. You could try moving the trimmer like a scythe. This will aid it as your cutting bit by bit.
Sep 27, 2013 | Husqvarna 28cc Gas Line Trimmer
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
Have 18.5hp briggs&straton and slows down in thick grass
its possible that the spring tension from the governor to the throttle linkage is weak
Jul 06, 2012 | Garden
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
