Question about Asko Washing Machines
My Asko W6022 machine starts the wash cycle and after a few revolutions the machine stops and drains the water.No fault indicators light up. What can be wrong?
  • 351 Answers
SOURCE: Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
Posted on Apr 09, 2008
  • 5 Answers
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
SOURCE: Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Posted on Nov 11, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
My Asko W6022 quattro 1200 rpm is giving me trouble. The delicate cycle doesn't work and just soaks the clothes. Please help.
may have defective timer (burned points at the delicate cycle mode) can but may be difficult take timer apart and sand paper clean the point contacts on timer DONT IT BEFORE BUT NOT EASY
Dec 16, 2014 | Asko Washing Machines
Asko w6022 flooding root cause
Yes that can cause a flood.
Sep 19, 2017 | Washing Machines
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Mar 10, 2009 | Asko W640
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Fault indication: water inlet fault
see if there is a blockage in the level switch. the switch operates on air pressure within the dip tube and the diaphragm in the switch. there may be a spider's nest in the tube or a wasp's nest in the tube.
Feb 03, 2008 | Asko W640
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
