Question about Zanussi Washing Machines
Bose repair melbourne
Error 40
Where can I repair my New Home Memory Craft 2000 Sewing machine in Melbourne Fl
check the sewing machine repairers in the Melbourne yellow pages and see if any are listed as authorized service agents for that brand
if you don't see any just call the biggest add and ask them if they know
Sep 05, 2016 | New Home Sewing Machines
Bose Remote RC28T1-40 batteries run out of power
There should be a short circuited component/s [capacitor/s] inside it. Contact any service technician to replace it.
Oct 27, 2015 | Bose Televison & Video
Is there a product like WD 40, only for stuck terminal tabs. Mine are stuck on Bose accoustimass 3 speakers . A terminal tab is pushed in, will not pop back out, and the wires will not stay...
Never use WD40 or any other petroleum product on anything electronic including the terminals. You may have to remove that terminal and repair or replace it. Good luck.
Mar 06, 2011 | Bose Acoustimass 3 IV System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Speakers rattle and Low end is gone
Hi!
The good news is yes, they most likely can be repaired. I owned a pair of 802's (their professional line, but very similar to your speakers) and repaired them myself.
Since you have a warranty, I'd suggest contacting Bose to find the nearest service center.
Email support@bose.com or call them toll-free and talk with a Bose Support Specialist to determine the service options for your product.
In the US: 1-877-210-3782
Monday Friday: 8:30 AM 9:00 PM ET
Saturday: 9:00 AM 6:00 PM ET
If you can't find a nearby service center, you may be able to contact a local stereo store and ask them about service. The 901's were a very popular speaker, and if you live near a large metropolitan area, you should have no problem finding someone to help you fix them.
If this was helpful, would you please rate it as such?
Apr 22, 2009 | Bose 901 VI Main / Stereo Speaker
Gettng my RC28T1 40 to connect with my LS28 system
i have a bose control, model RC48S2-40 and start the system but does not have control for volumen and change only from fm to cd dvd, is conected to other system bose from other rooms
Apr 10, 2009 | Bose RC-18S Remote Control
Bose Acoustimas with error 10
Error 10 is either a disconnect from the audio input cable (check the pins on both ends) or the Acoustimass module has no power. Check the outlet etc. If resetting it (unplug both components for 30+ seconds) doesn't fix the problem. Call Bose for a repair.
Aug 31, 2008 | Bose Lifestyle 28 System
Bose audio system error codes 31,33,30?
The trunk mounted 12 disc magazine changer with the Bose audio system is made by Pioneer. Mine is a bit flaky too so I try to avoid unnecessarily swapping out the CD's. Those error codes can mean anything from a defective/wrong disc type (it does not support MP3 discs), a disc being upside down, or forgetting to close the magazine loading door. It can also indicate condensation on the laser lens or a system malfunction. There may be a list of error codes in the owner's manual if you have one, I currently don't.
Assuming you have checked all of the possible human errors above, there are aftermarket sellers that claim you can adapt an aftermarket changer to the Bose system albeit with with inferior sound quality to the original system. Bose is typically well-known for it's audio quality. That being said, the other option would be to seek a repair facility that can repair these changers. There are some places on-line that repair car audio that also might be able to help.
A cheaper workaround might be to hook up a portable CD/MP3 player using a cassette adapter. Assuming the cassette player, amp and speakers are good, you would possibly still get fairly high quality sound from the Bose system.
Best of Luck!
SC442299
1996 Oldsmobile Aurora
4.0L DOHC 32V V8
Bose Audio w/ 12 Disc Changer
Autobahn Option
Jun 23, 2008 | 1996 Oldsmobile Aurora
Bose P1 - lost backlight
Bose support repaired two P1 remotes for me. The first one they did for free (well out of the warranty period). The second one in the last 18 months cost $50 for a complete rebuild, new case, etc.
Feb 20, 2008 | Bose 023795 LCD Touchscreen Remote Control
Error code
Contact them with the serial number from the media centre. They'll send you a software update disc free of charge. You just put the disc in the system, allow it to play and it updates the software. this solves this problem in most cases.
If not, it sounds like a drive failure - a repair is the only option and Bose are the best people to do it. Like all manufacturers, they'll quote a long date just in case - but normally their repairs department work faster than you expect!
Jan 09, 2008 | Bose 3·2·1 II System
Washing Machines Logo
15 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
