Classifications of noise - Computers & Internet
How do you fix error code U0151 in a 2014 Lancer?
i'd start by rechecking the "MDS on" install to make sure all connectors near where you were working are well seated. also recheck where the previous harness would contact. i find it really hard to beleive that the old harness was too short. improperly routed perhaps, but too short???
U0154 - LOST COMMUNICATION WITH OCM (occupant classification module)
  • When Monitored:
  • With the ignition on
  • IOD fuse installed
  • FCM is configured correctly
  • Set Condition: Bus messages not received from the Occupant Classification Module for approximately 2 to 5 seconds.
Possible Causes
CAN B BUS CIRCUITS OPEN OR SHORTED
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
FCM NOT CONFIGURED CORRECTLY
OCCUPANT CLASSIFICATION MODULE
OCCUPANT CLASSIFICATION MODULE POWER AND GROUND
MODULE THAT SET THIS DTC
OCM is located under passenger seat. make sure it's connector isn't loose.
Dec 10, 2016 | Cars & Trucks
Codes b1650 & b1785 on a 06 corolla came on what it posibly be?
B1650 Occupant classification System malfunction there are 4 possible trouble area No.2 floor wire,Front RH seat,center air bag assemble.
B 1785 Front occupant Classification Sensor LH collision Detection there is only one possible location to set this code Front seat LH
Sep 13, 2011 | 2009 Toyota Venza
What are the classifications of PECS
what are yhe classification of pecs
Jun 23, 2011 | Computers & Internet
I don't know what are the 3 classification of science?
The main three classifications of science( as per academic) are the following:
Physics
Chemistry
Biology( Botany and Zoology)
In common we have different classifications too..
computer science
social science.. etc..
Jun 08, 2011 | Computers & Internet
Need engine oil capacities for a 2.7L Hyundia
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA SJ/A2
Ambient temperature range Moderate climate
Engine oil grade SAE 10W/30
Ambient temperature range Moderate climate alternative
Engine oil grade SAE 10W/50
Ambient temperature range Hot climate
Engine oil grade SAE 10W/40
Engine with filter(s) litres 4,5
Feb 24, 2010 | 2006 Hyundai Tucson
DTC B1650 occupant classification system fault. 2007
If the vehicle has been in a rear end collision, expect this. If not, it just may need to have the Occ Class Sys reset. Toyota Dealer only.
Jul 18, 2008 | 2004 Toyota Prius
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
