Question about Red Line Synthetic Oil 60202 Lead Substitute 12/12oz
Can I substitute sodium bicarbonate for chalk in a recipe?
  • 39 Answers
I don't think so as they are different one being calcium carbonate the other as you say sodium carbonate not really the same thing. Have to admit I have never seen a recipe that actually specified chalk as a component part of a recipe but we live and learn!
Posted on Oct 06, 2014
    New Friend:
I'm afraid i can't help you - try a cookery expert
Posted on May 12, 2014
Where can i get baking soda shops only seem to have Bi-carb
Bicarbonate of soda is the same as Sodium Bicarbonate which is the same as Baking soda. Same product with different names.
Nov 27, 2017 | Refrigerators
Is baking powder and Bi-carb soda the same thing or are they different?
SODIUM BICARBONATE (BAKING SODA) IS USUALLY CONTAINED IN BAKING POWDER
Nov 27, 2017 | Washing Machines
How to get details about low sodium dog food?
call the manufacturer of dog foods . this is not a repair question we can assist with
Feb 01, 2017 | Dogs
Brew rite cleaner.powder in a 8 oz plastic container,the ingredients clean iron resevoirs great.Sodium Bicarbonate is that the only elements in the product?Well it cleans coffee pot and glass great.Thanks...
Brew rite cleaner contains sodium carbonate, NOT sodium Bicarbonate. Sodium bicarbonate is just baking soda, but sodium carbonate is a highly caustic chemical.
According to the MSDS, it contains 40-50% sodium carbonate,
3-5% sodium tripolyphosphate and 10-15% sodium perborate tetrahydrate. The other ingredients must be nonhazardous (fillers, abrasives, etc)
As to frequency of use... it can't damage glass. It might do damage to other materials.
Sep 26, 2013 | Coffee Makers & Espresso Machines
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
I have several SM58s and one is about 30 years old. Repeated removal of leads has worn out the grip hole at the bottom of the body so that leads just slip out. I guess what I really need is a shell. Is it...
Possible solution is fixing with rapid glue. If you put sodium bicarbonate on cianofix glue, it create heat and hard joint. Cleaning with brush and repeat more layer of glue with bicarbonate (baking soda), you can create hard seal. Interesting (but not hard) seal with acetic silicone with around 10% of sodium bicarbonate, can speed up process of creation of silicone (because of creating water inside silicone when sodium bicarbonate neutralizes acetate from silicone).
Aug 23, 2011 | Shure SM58 Professional Microphone
Water in pool seems cloudy now
If it seems clowdy now it is probably low on chlorine and unless this is corrected it will turn green in within a day or two. My suggestion is that you bring a sample of your water to a pool supply store and they will test it. If you have filled the pool recently with new water the two things you should be most concerned about are chlorine, stabilizer ph and alkalinity. Since your pool is clowdy the chlorine should be about 10 ppm and the stabilizer should be between 30 and 50 ppm. If you are short on stabilizer the chlorine will be gone very soon. If you have too much stabilizer the chlorine will say in the pool but it won't be as effective. Since the water is new the ph and alkalinity should be ok but the source of your water might be poor. Alkalinity is based on the amount of sodium bicarbonate (baking soda) in the water. If the level is right it helps keep the ph stable. Most municipalities supply water with 80 ppm of sodium bicarbonate in order to maintain their ph more easily. If the ph is too high it is base and causes the chlorine to be not as effective and it causes other problems when it is too low. Adding acid to the pool reduces the ph and adding sodium carbonate or sodium bicarbonate increases the ph. Since the water is new I would automatically shock the pool to 10 ppm of chlorine and treat with stabilizer to 30 ppm and then see how it goes. I wouldn't let anyone swim until the chlorine drops to between 2 and 4 ppm, the pool bottom is clearly visible and no dirt, etc is visible. I hope this helps.
Aug 13, 2011 | Intex Krystal Clear Model 635 Pool Filter...
NaHC03 need to no what the elements are ?
NaHCO3 is Sodium Bicarbonate. It is composed of a Sodium molecule (Na) and a bicarbonate (HCO3). The bicarbonate is broken into a hydrogen (H), a carbon (C) and 3 oxygen (O3).
Jul 01, 2011 | Computers & Internet
Has the antacid Brioschi been discontinued? I can not find it in any store anymore.
brioschi is a sodium bicarbonate you might find supplement at your pharmasist
Feb 27, 2011 | Health & Beauty
Our ta keeps falling by fifty in like just a few hours why?
Presumably you are referring to Total Alkalinity - assuming that your test kit/procedures are OK, the reduction is caused by a build up of acidity in the water. The addition of sodium bicarbonate will neutralise the acid; the fact that the ta keeps falling suggests that you either have a large amount of acidity and you aren't adding enough sodium bicarb to complete the job, or you may be adding acid in the form of a pH decrease chemical. To raise the total alkalinity by 40ppm you need to add sodium bicarbonate at the rate of 700 grams per 10,000 litres of pool water. The desired ta is about 100ppm.
You don't say whether this is a swimming pool or a spa pool - if it's a spa pool I suggest you drain it and start with a clean slate, so to speak. If it's a swimming pool you are probably being timid with the sodium bicarb!
Jan 24, 2011 | Pool & Spa
Red Line Synthetic Oil 60202 Lead Substitute 12/12oz Logo
57 people viewed this question
Top Redline Bikes Vehicle Parts & Accessories Experts
baire
nottmdon
k24674
Are you a Redline Bikes Vehicle Part and Accessory Expert? Answer questions, earn points and help others
