Question about Kodak EasyShare LS743 Digital Camera
Olympus x840 screen displays 'empty batteries' even tho fully charged batteries installed
    Top Expert:
  • Kodak Master
  • 6,702 Answers
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Posted on May 12, 2014
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
Camera says battery empty
When you finished chargin the batteries, was it fully charged? Are you using the AC cable that was provided to you witht the device? if your camera showed that it was fully charge but discharge even though you dont use the camera,I would recommend you to replace the batteries on the device....
Jan 17, 2008 | Olympus FE-210 Digital Camera
Where can i get a manual fo ror the X840?
Here is the answer for your requirement.
Please follow the below link and download the manual for Olympus X840.
Please Note : this manual is for all three models i.e. FE-310/X-840/C-530
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_fe310_e.pdf
Sep 22, 2009 | Cameras
OLYMPUS FE360U BATTERY DOES TURN ON
the LCD screen is malfunctioning
Repair it with the help of a professional immidiately to prevent further malfunction
Jun 30, 2009 | Olympus FE-360 Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
Apr 13, 2009 | Olympus FE-210 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Shows empty battery even with new batteries
If they're AA, don't use "HEAVY DUTY". They don't have enough power. Use alkaline or rechargeable, and recharge at least 15 hours even if your charger show they're fully charged after a couple hours. Please leave feedback if this helps.
Jul 26, 2008 | Olympus FE-210 Digital Camera
Drained batteries
Digital cameras do use a lot of power to operate. Somethings can make the batteries die faster. Even if the batteries may have worked in other cameras after ou used them in yours could just be that the other camera requires less power to operate then yours. Turning off and on the camera or simple viewing them can use more power then usual. Try and avoid this to see if it last longer. Also, try and see if there is an auto shut of to save power when you leave the camera on. If you have an eye piece use that to take pictures instead of the display this will also save on power consumption. Also, when you know that you won't be using the camera for awhile meaning you are storing it then remove the batteries. Some electrical items even if the camera is off they can still be draining the batteries.
If these don't help then I would have it looked at especially if you are under warranty.
Jun 09, 2008 | Olympus SP-550 UZ Digital Camera
Battery empty
Try using fully charged rechargeable NiMH.
Oct 19, 2007 | Olympus Camedia C-350 Digital Camera
Open Questions:
Kodak EasyShare LS743 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
