Question about Mk Diamond MK 370 TILE SAW
Rebuild mk 370 tile saw
How do i change the bearings
thabrain
  • 76 Answers
SOURCE: Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Posted on Nov 05, 2008
muttandjeff
  • 359 Answers
SOURCE: Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Posted on Dec 03, 2008
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 55 Answers
SOURCE: I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Posted on Dec 02, 2009
  • 55 Answers
SOURCE: I am trying to find an wiring diagram for a tile
Here is the website you need to find the manual and wiring diagram for your saw
Hope you find what you are looking for
http://www.mkdiamond.com/tile/saw_660.html
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
The saw has a burning smell. What could be causing this?
it might be electrical,i hate the cord they put on those saws because they have the reset built into the cord,that saw doesnt have a belt,& i doubt its the bearings,good luck
Mar 02, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
I have two 101's and both saws have a terrible wobbling. I have put new blades on both and no corrrection. I put the same blades on a 10" target and they boith cut perfectly....i am at a loss
well you might check the belt tension,you can tighten it by loosining the 4 nuts that hold motor then tighten the middle bolt in the back,that slides your motor forward,then retighten the 4 motor nuts.if saw sounds louder than normal, it probably needs new bearings
Nov 17, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
I am trying to find an wiring diagram for a tile saw mk-660
Nov 30, 2009 | Mk Diamond MK - 660 Electric Tile Saws
Mar 31, 2009 | Mk Diamond MK - 1070 Tile Saw
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Mk Diamond MK 370 TILE SAW Logo
69 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
