Question about Canon PowerShot SD850 IS Digital Camera
Ixus 70 postcard mode - Canon PowerShot SD850 IS Digital Camera
I have a cannon Ixus 75 digital camera, which I have had for several years, and cannot get the date to print on the photo's. I have set the date and time as instructed in the namual, but when I go to...
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again.
Dec 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to turn on date stamp
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard. Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Dec 11, 2010 | Canon IXUS 860 IS Digital Camera
Hi all, pls hep me to set up the date stamp on my canon ixus 75. i used to have it on my camera. Thank you
The date stamp only works in Postcard mode. Press Func/set, scroll down to the bottom, then across to the mountain with clock icon. "Postcard" will appear in the selection. Press Func/set.
Now press Menu, scroll down to Date Stamp and across to set date or date and time, then press menu again.
Dec 04, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How can I get the date to appear on my pictures for downloading ?Canon ixus 75
On my Ixus 70, I can only "embed" the date on pictures when "Postcard Mode" is selected. Press "Func/Set", go down to the bottom icon on the left (sets picture size) then go right to "Postcard" (looks like mountains, will say Postcard when selected) then press Func/set button again. Now press "Menu", scroll down to "Date stamp" and set it to "Date" and press "Menu" button again.
Once embedded, the date cannot be removed later.
Nov 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
Date Stamp & Formatting SD Cards
The "postcard" option is not available in the digital macro (flower with a D on it) or stitch assist modes, nor in any of the movie modes. If you're in any other mode, it should be available under the size option (bottom icon on the function menu).
There may be a way to get your images back if you haven't taken any pictures after you formatted your card. Do a google search on "image recovery".
Jan 19, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Can anyone tell me how to get the date to appear on my photos using a Canon Ixus 70 camera?
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 01, 2009 | Canon Cameras
Date time stamp
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Sep 07, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Date stamp on my ixus 50
The Date/Timestamp is only available in Postcard Mode, so push FUNC/SET, scroll down and set the size to Postcard.
Aug 23, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon Ixus 850 IS
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Jun 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD850 IS Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
