Question about LG Washing Machines
Why is there no power gegtting to my lg washer?
My lg TROMM WM2277HS washer shows no lights on it display. It is plugged in but no displa i did check the outlet is hot!!! What do I do Next?
  • LG Master
  • 1,525 Answers
Hi look inside the washer on the circuit board for a glass fuse, or there may be a soldered in one called a wickman fuse, you will need a multimeter to test them!! hope it helps
regards
shaun
Posted on May 18, 2014
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
SOURCE: own LG Tromm Wm2277hs
may be the sensor? I have the same model and I changed the sensor now it fills.
Posted on Jun 14, 2010
TheMobilian
  • 8220 Answers
SOURCE: My LG Tromm washer WM2277hs
OE: Drain problem took longer than 10 minutes to drain
Posted on Sep 03, 2011
Have an LG Tromm WM2277HS washing machine the water will not drain and of course will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Washing Machines
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Sep 14, 2009 | Washing Machines
Front load washer leak
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Jan 18, 2009 | LG WM2688HWM TROMM SteamWasher
Own LG Tromm Wm2277hs
Jan 17, 2009 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
