Question about Bosch Classixx WFL 2066 Front Load Washer
DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
Fault code F18 again but filter been cleaned,again,and is spotless.will spin when clothes taken out.Works perfectly otherwise but why does this code keep appearing?
  • 63 Answers
I would check that the drain pipe is also clear.
You can actually get a build up of old soap powder in the pipework.
This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
I found this answer that may help you.
https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
Posted on May 12, 2014
Testimonial: "WOW,thank you so,so much.Obviously i only ever cleaned the filter,but when we checked the drain hoses about 1lb of scale came out.Now she's working perfecty,so thank you once again."
  • Worldhosted May 12, 2014
    The problem happens with cool washes.
    Every month or so, try doing a boil wash with an empty drum. Gives the machine a chance to blast everything out :-)
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
I have a Bosch Classix 6 1200 Express that stopped working 23 minutes before the end of the cycle. It has been noisier recently but this time it stopped altogether and when I tried to spin the clothes the...
Hi davidandsall,
Before it can Spin (The last part of any cycle), it would need to drain the water first. Your machine is stock on that particular position, most likely because of a clog in the Drain Filter compartment.
You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Washing Machines
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
My Bosch Logixx has stopped working and displays F18. It is also flashing.
Bosch 'F18' decodes as 'pump/drain out time' so I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 29, 2011 | Bosch Washing Machines
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Classixx WFL 2066 Front Load Washer Logo
302 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
