LG intellowasher 7kg WD1021WH
Goes through each cycle but with no movement in the bowl no spinning movement releases water and the timer etc but that's it can I fix it myself to spin again
  • 1294 Answers
SOURCE: LG INTELLOWASHER STOPPED SPINNING
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 02, 2008
beltronic205
  • 1474 Answers
SOURCE: my washing machine is not spinning anymore
Do not think this is the problem. Make sure pumping out properly,,Could also be motor brushes if its an older machine...
Posted on Nov 10, 2009
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
werven283
  • 29 Answers
SOURCE: LG front Loader Intellowasher 7kg WD-8015c has
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Posted on Jun 21, 2012
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher 7kg wd8015c
OVER LOADING YOUR FRONTLOAD WILL DAMAGE CENTER CARRIER BEARING
Aug 17, 2013 | Washing Machines
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
You are right!
Apr 07, 2010 | Washing Machines
Is there a filter in the LG INTELLOWASHER 7kg. If so where is it. The model is WD-8074FHB
its located on the bottom right of the machine front - open the flap and you will see a round filter base. ONLY OPEN THE filter during the last of the spin cycle to clean it, this is when most of the water has been pumped away. Opening it while the machine is off will cause a gush of water over the laundry floor.
Feb 08, 2010 | LG Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
