Question about Cameras
How to change ribbon ink on yokatta dx6 - Cameras
I NEED SCHEMATIC DIAGRAM OF YOKATTA DX-6. KINDLY PROVIDE ME.
Request the DX-6 schematic diagram directly from Yokatta.
Jun 23, 2018 | Televison & Video
HOW DO I CHANGE THE INK IN THIS OLD CALCULATOR? THE RED IS COMPLETELY GONE AND THE BLACK IS VERY LIGHT
What model is the calculator and if it's a inker type then you have to replace the ink roller. If it's the ribbon type then you have you replace the ribbon. You can pick those inker or ribbon from Edmonton Cash Register Co. Ltd. or send us a email to order
Apr 10, 2015 | Casio HR 100TM Portable Printing...
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
How do I change an ink ribbon?
lift the lid lift old ribbon cartridge off snap a new one in
Sep 11, 2014 | Brother Gx-7750 Correctronic Electronic...
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
I want to change the printer ribbon on Zebra s600 203 dpi, is there a way it will rewind existing ribbon off?
Thermal printers don't use ribbons or ink. They transfer images/text with heat on to special thermal paper.
Mar 23, 2011 | Zebra Stripe S600 Thermal Label Printer
How do i change the ink cartridge
No ink cartridge - the ink is on the ribbon. Replace the ribbon if out of ink.
Dec 14, 2010 | Sharp EL-1801P Calculator
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Brother intellifax 770
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 25, 2008 | Office Equipment & Supplies
Zebra 105SE
make sure the ribbon is installed properly. The thermal ribbons are only coated on one side with ink. Make sure the right side is facing the paper. If that is not the issue the thermal head might be bad.
Jun 26, 2007 | Zebra 105Se Thermal Printer
Cameras Logo
252 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
