HLT5055WX/XAA Has intermitant sound distortion
Sound will pop sometimes and then people sound like they have inhaled Helium, and there seems to be a slight echo. The volume seems to drop also. On Charter TV system, box hooked up to TV w/HDMI cable. I have reset charter box by unplugging and rest tv sound w/remote.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on May 12, 2014
  • Carl Matson May 13, 2014
    Had Charter change out the cable box and changed TV menu from dynamic/stereo to TV Speakers and so far (24 hours) the sound is just fine. I will comment later if more problems develop with the sound. Thanks to all for their suggestions
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Posted on Mar 29, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
SOURCE: Need remote code for LC420SS8
I Have the same problem & call Sylvania, they advised there is no remote code
Posted on Apr 07, 2009
SOURCE: Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Posted on Apr 12, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 31, 2017 | Televison & Video
Sound is too fast sounds like someone inhaled helium
try to play a dvd or other sources then try again..if the problem persisted try to restore factory settings.
Nov 03, 2012 | Samsung SyncMaster 710MP 17 in. LCD...
I have a Pioneer projection tv LS-501 almost 30 years old only problem intermitting distorted sound, cracks then normal sound then crack and back distortes. when I turn audio up high sometimes it pops back...
hi there.most likely there are dry joints on the audio ic..a few sharpish taps on the main board should make the fault come and go if thats the case, just a little bit of resoldering should do the trick.hope this helps, steve
Sep 11, 2010 | Pioneer Televison & Video
The sound coming out of my laptop is like someone has been inhaling helium any ideas. Have connected headphones but its the same.
Hi
Thank you for your query
Please try the following
1) Look in your system tray (where the time is), there will be a icon of a speaker, please click on this (Please do not confuse this with the volume of your speakers, if you hover your mouse over this icon it will say RealTek Sound)
2) Once realtek sound properties has opened up find the option that says sound effects
3) In this tab there will be a option entitled 'karaoke', if your sound is high this may have a high figure on it, change the value to 0
Hopefully this will cure your issue
I hope this has been helpful
Mar 01, 2010 | Acer Aspire 5735 Notebook
Sound problem chipmunk voices on my acer aspire one. All of a sudden, every voice on my acer aspire laptop sounds like a chipmunk, or as though the news anchors have inhaled helium. How do I fix it??
Realtek sound has an "Audio Manager" control panel thing of sorts that can be opened by right-clicking a tray icon or using a shortcut in the control panel. The audio manager features a "pitch" setting that can get changed accidentally. All you need is to located that setting and return it to zero. Young children have a talent for finding this setting and changing it without letting the adults know that they have done so! Sound familiar perchance?
Feb 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
Dvd people sound high pitched or inhaled helium
You Need To Install The Correct Audio Codec which will correct the issue...
http://www.afreecodec.com/audio-codecs/
the link above has free codecs for download..
I'm not able to tell which one you need so best thing for you to do is start from the first one, download/install it then test the dvd...then go on to the second audio codec and download/install Until You Get The DVD To Sound Normal...
THe Codecs Are Extremely Small In Thier File Size... So DOn't Worry About Any Space Being Taken Up From Downloading These... You Might Have To DL Quite a few before you get the correct one...
Also You Can Do A Google Search For: XP Codec Pack......
Download that and it will auto install about 10 or so of the most common Audio Codecs along with video codecs...
Dec 08, 2009 | Everex StepNote LM7WE Notebook
When listening to podcasts the voices sound weird
Try updating the drivers for the soundcard. The pitch change could be a sampling rate error.
Apr 17, 2009 | Audio Players & Recorders
MY SOUND CARD SOUND LIKE
check device manager for your sound card, and tell me what it is. also, your software your sound card uses.
most sound changes comes from the software.
Nov 15, 2007 | Acer (54.AA806.001) Sound Card
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
