Question about Pool & Spa
How much sand does a Tagelus 230 have - Pool & Spa
2 Suggested Answers
SOURCE: davey tagelus 230 high rate sandfilter how do i change the sand
Once you have removed the plumbing connections and the top selector plate you can then unscrew the top from the main filter body, This is not easy and you will have to use a 5 lb hammer (lumpy) and a block of wood as the top has been siliconed to the body and made a tight fit. Be very careful with the hammering and make sure you only put the wood against a solid part of the top near a plumbing joint before applying the hammer to the end of the wood. There are about 6 complete turns before the top part is unscrewed. The threads will need to be cleaned and the old silicone removed and clean the sealing gasket "o" ring before putting back. My model did not have an "fingers" at the bottom of the central stalk. I believe the filter should be filled 2/3 with the proper filter sand grade 16/30
Hope this helps
Robin Moseby
rmoseby@internode.on.net
Posted on Nov 24, 2012
I have sand coming out of the bottom of the davey tagelus 230 sand filter and in the pool. is this repairable with a service or should after over 25 years look at a replacement?
25 years????
That is awesome, and you absolutely got your moneys worth.
Get a new one, but if budgets are slim, as with most of us, then you can repair your filter...
Get a new drain and lateral assembly. (that is what failed)/
You will need to know the size and or model of your filter.
You will need to remove the valve if top mount; shop vac all of the sand out then rinse tank.
Install the new lateral ass\'y then...
Add new filtration media (recommend glass over sand) and reassemble any plumbing removed to access internal of tank.
Good Luck
Sep 05, 2014 | Pool & Spa
Pentair tagelus t60d filter filtering algae back into pool
Have you backwashed the unit? That would clean out remaining algae.
Jun 18, 2014 | Pentair Tagelus TA 60D Filter
I'm getting a little sand in the discharge during back wash
that is usually caused by damage to the fingers (laterals) on the standpipe. most times this damage comes from improper winterization or when sand is changed by non professional
May 30, 2014 | Hayward SAND FILTER, PRO SERIES
Pentair Tagelus 60 sand filter- why is valve always so difficult to install?
1st why are you removing the valve so much? you might be proforming a routene task incorrectly . also when i put any valve back in i allways give it a lite coat of waterproof grease on o-rings and ball cock, this stuff can be got from any well stock hardware store in the kitchen sink section (same stuff you use on faucets) so you know it\'s food grade ,dont use car grease !!!!
May 14, 2014 | Pentair Intelliflo Vs3050 4speed Pool Pump...
Change sand in tagelus filter
So you have a "TA" filter. Which size?
It does not matter really, otherwise I would have been able to know how much sand you you have to remove and how much to put back in.
Anyway, To change sand you have to remove the MultiPort Dial valve on top.
Then, you can either unplumb the filter and roll it over on its side and using a garden hose, start washing the sand out or use a shop vac, with keeping it upright.
Whatever you do NOT damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. Always fill the filter half full of water, at least over the laterals by a few inches, to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand! And... cover the stand pipe!!! Use duct tape or some kind of covering (spout cut off a water bottle then covering the pipe). Otherwise you will get sand into the standpipe and into the laterals, then you have another problem.
Apr 23, 2014 | Pool & Spa
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
GASKET CHANGE: What steps should I follow to change a leaking gasket on the diverter on the valve of my DAVEY TAGELUS 230 sand filter?
make sure the valves on the outside of the pool are closed so when you open up the valve to change the gasket the pool water will not continue to run out of the filter.
Once you are secure about water flowing out of the pool through the filter you can remove the bolts holding the filter body together and change the gasket.
Rod
US Parts Center
Feb 06, 2013 | Pool & Spa
Can't get my pool water the right clarity no matter how much chlorine & chemical wonder if I need to change the sand in my tagelus 230
Changing the sand should do the trick. Those relatively small filters can load up with debris and oils quickly. The pump doesn't always have enough power to effectively rinse out the filter during backwash, especially if the sand is old and loaded.
One thing you may want to do is use a flocculant to drop all the suspended particles to the floor, then vacuum to waste. This will prevent all that dirt from getting into the new sand.
Jan 20, 2013 | Pool & Spa
Davey tagelus 230 high rate sandfilter how do i change the sand
Hope this helps
Robin Moseby
Feb 18, 2012 | Pool & Spa
How do i change the sand in the hayward e1001542s
we have changed the sand in our filter but now we cant get the back wash to work we have a davey tagelus 230 i need a diagraham to show how to put the muliti flow value on again
Oct 26, 2008 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
61 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
