HP Laserjet prints everything multiple times
My HP Laserjet 1200 printer prints everything multiple times on the same page, each subsequent image is 4-5 centimeters away from previous and fades out more and more.
Changing cartridge does not help.
  • khebul Jun 23, 2009
    Thanks for answer. Yes, same image repeats multiple times. So I'll contact nearest service center then.
    President:
  • 1,185 Answers
Is it the same image being repeated ?
If so then it is the drum not the developer unit.
There is a device for discharging the image once it has been transfered to the paper from the drum.
If that is broken then the image is not cleaned off and will repeat.
The other thing to look at is your setup to make sure it is set at A4 and it is being told to print one copy per sheet
Posted on Jun 23, 2009
  • Tom
    Tom Jun 23, 2009
    You could try removing the drum unit and make sure that the cleaning blade that sits against the drum does not have a piece of paper caught between it and the drum or that you have toner built up which can cause the same thing
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
My hp laserjet 1200 series printer will not stop intermittantly printing single pages of a multi page document holtbldr@bellsouth.net
Turn off computer,turn off printer disconnect comm cable for 5 min,reconnect reboot should stop intermitted printing
Jan 18, 2011 | HP LaserJet 1200 Printer
When scanning multiple pages, first page prints ok but subsequent pages just print lines and greyed characters
When you print to the M2727nf does all the prints come out ok? If they do you might want to get some canned air and blow out the adf assy and clean the scanner glass. If this does not work find the settings on the printer to do a scanner calabration, it will tell you how to do this from the display.
Jan 07, 2010 | HP Laserjet M2727nf Multifunction Printer
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
HP Laserjet 1200 will not feed paper
remove the toner cart and clean the gray roller behind it with alcohol
Jan 28, 2009 | HP LaserJet 1200 Printer
Images of previous page remains on the new printed page
It is either a bad drum in the toner cartridge or toner on the fuser. Try changing out the toner. If the problem remains, you'll have to get a new fuser module.
Nov 29, 2008 | HP LaserJet 1020 Printer
HP Laserjet 1200 not printing in one area
your fuser is truly unhappy..time for a new fuser
May 28, 2008 | HP LaserJet 1200 Printer
170 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
