Question about Sam4s ER-180T Cash Register
There is a numbered error and a screeching sound coming from the register
The sound is screeching when the volume is louder
that screeching is called feedback..which is caused by loop oscillation in plain english that means that sound is going from the speaker to the microphone and "looping" causing feedback noise or "screetching" there is nothing you can do but lower the volume it's a normal phenom not a fault in the product but more user error. sorry to say. the only thing you can do is lower the volume till it goes away.
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
Hi my Frifidaire dryer model number feq1442es is making a metal screeching noise somtimes when it is running
With frigidaire, more than likely the rear bearing is going out on if it the screeching sound is happening. the part number for that is 131825900 and will run you about $3.00. Go to apdepot to order the part if needed.
Oct 31, 2010 | Frigidaire FEQ1442ES Electric Dryer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
My 2005 rmz 450 makes a screeching sound when i give it throttle what could cause this thanks
About the only thing that would cause a screeching sound in the engine is bad crank bearings or a bad sprocket shaft bearing. A bad bearing in the rear wheel can screech as well. Just be sure where the screech is coming from.
Oct 23, 2009 | 2005 Suzuki RM-Z 450
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Get a screeching sound from unit when heater is on.
Chances are it is the outdoor fan motor. Does it squal when you run the A/C? If not it could be the reversing valve solonoid.
Jan 16, 2009 | Intertherm P3RA-048K Air Conditioner
Trying to switch out my base unit on the 9120 I am trying to trouble shoot a loud screeching sound that happens when I hang the phone up cant get my head set to switch to the new base
The loud screeching is probably due to the headset mic volume being too loud, or the campatability setting on the base station is in the wrong position for your phone.
To register a new earpiece to a base station, simply put the headpiece on the charging dock and leave it there while you disconnect the power, wait about 20 seconds and then reconnect the power. All the lights on the base should flash a couple of times and then the green charging light will start fashing as normal. The headset should then be registered.
Aug 20, 2008 | GN Netcom GN 9120 Professional Headset
Sam4s ER-180T Cash Register Logo
Top Sam4s Office Equipment & Supplies Experts
Scott Peeples
Scott Peeples
Level 1 Expert
Patrick Tinashe...
George Merkley
George Merkley
Are you a Sam4s Office Equipment and Supply Expert? Answer questions, earn points and help others
