Need Manual For Mitsubishi VCR HS-U28 ?
NEED MANUAL FOR MITSUBISHI VCR MODEL HS-U28
nfandres
  • 168 Answers
SOURCE: How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
Posted on Feb 26, 2007
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
  • 1153 Answers
SOURCE: Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Posted on Mar 22, 2008
robotek
  • 1512 Answers
SOURCE: Resetting the date on a Mitsubishi VCR HS-E51 (NZ)
hi 1pal
2003 has christmas day Dec 25 on a thursday, but this year was a leap year...hmmm Give it a try. We are past Feb, and will remain the same till the next leap year... and then you may have to put a peice of gaffa tape over the dial.... :)
ex pat
robotek
Posted on May 13, 2008
Where can I find a manual?
1. You might try mitsubishi.com. They have some VCR manuals available for download.
2. If no luck there, I suggest you go to ebay.com and search for:
"Mitsubishi HS-U680 VCR". Scroll through the listings and you may find someone who has listed a manual for your HS-U680.
Apr 20, 2016 | Mitsubishi HS-U680 VHS VCR
I need an owners manual.
Here is a link to the manual you've requested:
Mitsubishi HS U430 User Manual
best of luck!
Apr 13, 2016 | Mitsubishi HS-U540 VHS VCR
Manual for mitsubishi hs-u790
Try the Mitsubishi website they might have a free PDF of it
Mar 12, 2012 | Mitsubishi HS-U790 S-VHS VCR
Looking to obtain a HS-U448 manual and remote.
The manual is available from the Mitsubishi Support site: http://support.mitsubishi-tv.com/documents/HS-U448 . The direct link to the manual is http://support.mitsubishi-tv.com/files/oguide/HS-U448.pdf .
The original remote is no longer available. However, remotes.com has a substitute remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HS-U448&uuid=13065385902780 .
A number of universal remotes will probably also work. The codes will be in any remote that still controls a VCR if the remote was programmed after the HS-U448 was released.
I hope this helps.
May 27, 2011 | Mitsubishi HS-U448 VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Input selection
Many of the late VCRs have very limited funtion from the VCR buttons. Power, eject, play, perhaps channel selection, that is about it for most. I assume you don't have the manual? Looked on Mitsubishi website, didn't list a manual for your specific model, perhaps another model would be close enough. http://www.mitsubishi-tv.com/j/i/18344/OwnersGuides.html?tid=5&f1=2005&s=3 Replacement remotes here: http://www.vcrremotecontrols.com/Mfrs/Mitsubishi/MitsubishiVcr.htm
Aug 22, 2007 | Mitsubishi HS-U540 VHS VCR
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
