Question about LG WM Washing Machines
2277HS What Is the main problem to this washer I plugged this into a plug did 5 loads then it completely shut off. There was no trip at the main breaker juist went blank what should i focus on next?
  • 101 Answers
More than likely it went out on the thermal protection devise in the washer, most automatically reset after the motor cools down. Some are mounted at the rear of the washer.
Posted on May 12, 2014
rallupae
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
  • 28 Answers
SOURCE: will not turn on
If led'slight up when POWER button pushed but nothing happens when START button pushed ITis likelt to be lid reed switch open circuit or pump is open circuit .If nothing lights up when turned on at wall socket suspect controller dead or pump open circuit.Pump sounds like it has caused problem joker 120 need to check loop resistance of pump 35ohms for Aus/NZ
Posted on Jun 18, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 42 Answers
SOURCE: hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Posted on Mar 31, 2009
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
We finished a load of laundry and noticed it was still pretty damp after the wash had been completed. Upon attemping to do another load the washer will no longer work at all...Bit of a problem here any...
Are there any error codes at all displayed on the screen? Basic troubleshooting for this unit will be first to check to make sure the circut breaker is not tripped in the main breaker box, make sure if you have any GFI power outlets in the home that they are not tripped (they are normally near sinks or in bathrooms and have the "test" and "reset" buttons on them. They can sometimes be wired into a nearby washer outlet.) Make sure to not use any extension cords on the washer, and last of all unplug the washer for a few mintues and plug it back in to see if that will reset it. Sometimes unplugging it can reset any errors. Please repost if this does not fix the problem or if you find any error codes.
Mar 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Is there a lint trap on there a 2277HS LG washer
yes, underneath lower access panel on front of machine. be sure to drain water 1st via small drain hose.
Jun 12, 2010 | LG WM2277H Front Load Washer
Hotpoint aquarious wd 440 two years old tripping main board
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Won't start
We have a kenmore 27182 that has a very bad wabble in the spin mode. any suggestions?
Dec 22, 2008 | Kenmore 27182
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
