Question about Yamaha RX-V496 Receiver
How to set menu of yamaha rx-v496
Without remote
  • 236 Answers
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Posted on Mar 19, 2008
SOURCE: Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Posted on Mar 24, 2009
SOURCE: yamaha rx-v496 loses sound when change from dvd/ld
After switching back and forth now seems to work,(possible falty switch?)
Posted on Oct 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: I lost my remote to a Yamaha RX-V795 and can't
Use the SET MENU button on the front panel (next to the Level button and below the Tuning Up/Down Buttons.
Posted on Mar 16, 2010
John-INSG
  • 312 Answers
SOURCE: Trying to control Zenith DTT900 box with Yamaha RX-V463 remote
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
Posted on Jul 02, 2010
How to troubleshoot remote controll
Most Yamaha receivers have a remote ID so if you have more than one Yamaha you can control one without bothering the other, do you still have your owners manual? If not have you tried the people at Yamaha they are very helpful with a problem like this but for an example I have my Remote ID set at ID1 because I do have 2 Yamaha receivers the RX-V1300 and the RX-A3020, see if you can find the section in your manual that talks about remote IDs and let me know if that fixes the problem and you can always goto http://usa.yamaha.com/products/audio-visual/ but that is the site for the United States they do have sites for many countries at http://www.yamaha.com/
Apr 26, 2014 | Yamaha RX-V659 Receiver
Bad left channel on home cinema system
The output transistor is probally shot,
Dec 04, 2012 | Yamaha RX-V496 Receiver
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
My Yamaha rxv496 switches off after about 20 mins then switches on after about 10 mins.
sounds Like a power supply issue and u should always have speakers connected before u turn on maybe power supply is about done open case an check for any leakage on power supply unit or small cracks on it ...if so its pretty well done
Never good to power up without speakers connected can blow power outputs
Feb 07, 2012 | Yamaha RX-V496 Receiver
I have a yamaha rx-v496 and it won't stay on. As soon as I turn it on, it turns right off. Is this a simple fix?
Maybe.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 17, 2011 | Yamaha RX-V496 Receiver
I lost my remote to a Yamaha RX-V795 and can't figure out how to get out of the set up menu
Mar 16, 2010 | Yamaha RX-V795 Receiver
Hey, i have an yamaha rx v496
As long as you can connect the audio to the RX, no need for another amplifier.
Mar 01, 2017 | Yamaha RX-V396 Receiver
MY DTS is not working, not sure if connections are done correctly.
You have to use ether optical or coax connection, DVD disk has to have a DTS content (not every disk has DTS)
Dec 02, 2009 | Yamaha RX-V496 Receiver
Voices vs. sounds
If you are passing video thru the monitor out to the TV, this will go much easier. First Press the GUI Menu button on the remote. If connected to TV, on screen menu will appear. Go to Manual Setup then (right arrow on the 4 way with the ok in middle) Speaker Settings then Speaker Select then go to Center Channel arrow right again and make sure it's "On" If it is, then go back to the main speaker settings and toggle to Speaker Level. Then select center channel and arrow right turns volume up. If you still have no audio, post a comment and I can help you troubleshoot further. Hope this helps
Nov 19, 2009 | Yamaha RX-V496 Receiver
Yamaha RX-V496 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
