Question about Yamaha RX-V496 Receiver
Yamaha rx-v496 set menu
Set menu
4 Suggested Answers
SOURCE: yamaha rx-v496 loses sound when change from dvd/ld
After switching back and forth now seems to work,(possible falty switch?)
Posted on Oct 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: I lost my remote to a Yamaha RX-V795 and can't
Use the SET MENU button on the front panel (next to the Level button and below the Tuning Up/Down Buttons.
Posted on Mar 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a yamaha rx-v496 and it won't stay on.
Maybe.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 17, 2011
Bad left channel on home cinema system
The output transistor is probally shot,
Dec 04, 2012 | Yamaha RX-V496 Receiver
I have a yamaha rx-v496 and it won't stay on. As soon as I turn it on, it turns right off. Is this a simple fix?
Maybe.
Apr 17, 2011 | Yamaha RX-V496 Receiver
Volume to about between 40 and 28 causes receiver to turn off
It sounds like protect circuit is kicking in due to excessive current. If an OHM meter is handy, check for shorts on your speakers. If not disconnect one speaker at a time from the back of the reciever. Play unit at the volume that it fails. If it then plays fine you've isolated the bad speaker.
Aug 30, 2010 | Yamaha RX-V496 Receiver
I lost my remote to a Yamaha RX-V795 and can't figure out how to get out of the set up menu
Mar 16, 2010 | Yamaha RX-V795 Receiver
Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
Hey, i have an yamaha rx v496
As long as you can connect the audio to the RX, no need for another amplifier.
Mar 01, 2017 | Yamaha RX-V396 Receiver
No power
hello check the glass fuse inside.warning if you put another 1 in and blows again then there's a dead short somewhare
regards
shaun
Jan 16, 2010 | Yamaha RX-V496 Receiver
MY DTS is not working, not sure if connections are done correctly.
You have to use ether optical or coax connection, DVD disk has to have a DTS content (not every disk has DTS)
Dec 02, 2009 | Yamaha RX-V496 Receiver
Voices vs. sounds
If you are passing video thru the monitor out to the TV, this will go much easier. First Press the GUI Menu button on the remote. If connected to TV, on screen menu will appear. Go to Manual Setup then (right arrow on the 4 way with the ok in middle) Speaker Settings then Speaker Select then go to Center Channel arrow right again and make sure it's "On" If it is, then go back to the main speaker settings and toggle to Speaker Level. Then select center channel and arrow right turns volume up. If you still have no audio, post a comment and I can help you troubleshoot further. Hope this helps
Nov 19, 2009 | Yamaha RX-V496 Receiver
Yamaha RX-V496 Receiver Logo
18 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
